Computer codes?
Old 05-05-2006, 11:08 PM
98 Mustang GT
98 Mustang GT's Avatar
Default Computer codes?
Hey everyone, as you can see Im a newbie on here. My mustang is having a slight idle problem. When I reach a stop the cars idle goes from 800rpm down to 600rpm and then goes back to 800rpm where it stays. I know there is a certain sensor somewhere on here that needs replacement. Is there any way to check computer codes on these cars through the ignition for example On/Off/On/Off or does that not even exist? PLEASE HELP THIS NEWBIE OUT
98 Mustang GT is offline
Old 05-05-2006, 11:29 PM
sprostang
I ♥ Acer
sprostang's Avatar
Default RE: Computer codes?
Sounds like you need to clean the IAC. Heres what it looks like.
[IMG]local://upfiles/21900/A3073BDF45E8461582B34EA294F9A5A2.jpg[/IMG]
sprostang is offline
Old 05-06-2006, 03:34 AM
rbstang
rbstang's Avatar
thats normal... your cooling fan draws energy which lowers the tach the engine revs a little higher so the fan can run.
rbstang is offline
Old 05-06-2006, 03:50 AM
St4ng07
St4ng07's Avatar
Most likely your IAC or could be you MAS if you have a K&N Air filter take apart you MAS take a cue tip and electrolite cleaner and clean it off.
St4ng07 is offline
Old 05-06-2006, 03:57 AM
rbstang
rbstang's Avatar
IAC deals with rpms hanging during shifts...
rbstang is offline
Old 05-06-2006, 06:42 AM
97targa
97targa's Avatar
It sounds like your fuel filter, not an engine code.
And no you need an OBD-II scanner. Auto parts store for $40...model specific
$149 for universal for any car
IT IS NOT YOUR AIC VALVE.....DON'T LISTEN TO THES IDIOTS.
97targa is offline
Old 05-06-2006, 12:10 PM
SilverGTV8
SilverGTV8's Avatar
Dude you are such a tool....
It is a known fact the the IAC causes a MOST of a mustangs idle issue.
It is an easy thing to pull off and clean up to see if it resolves the problem. It is always a good idea to replace the fuel filter after 30k.
But the fuel filter HAS NOTHING TO DO WITH THE SYMPTONS THE CAR HAS! If he came on and said the car is sluggish under acceleration, feels like it has a miss etc. Then it could possibly be a filter. IAC is usually the culprit fow what he is describing. Pull it clean it up and see if that resolves the problem.
It would also help to know what year the car is (it may not be OBD-2 Mr Brain......) auto or stick, when it does this do you have any of the HVAC controls on? If so what position?
The AC compressor when it kicks over can put a strain on the motor and will be more noticable in an Auto.
ORIGINAL: 97targa
SilverGTV8 is offline
Old 05-07-2006, 12:55 AM
rbstang
rbstang's Avatar
your having an idle problem cuz of the fuel filter ROFL !!!!!!!!!!!!!!!!!!!!!!!! thats funny
but ya. like silver said HVAC and also the cooling fan like i said draw energy from the engy which causes the engine to go down a little bit then go back up. You can clean your IAC but i bet it will keep doing it because its normal...
rbstang is offline
Old 05-08-2006, 03:15 AM
98 Mustang GT
Looks like two 10mm bolts and that will come easy right? What should I use to clean that sucker? I appreciate all you gurus who are on here helping me out. BTW it is a 98(like the name says) and its a stick!!
Old 05-08-2006, 03:19 AM
St4ng07
St4ng07's Avatar
Are you positive its only 40$
St4ng07 is offline
Quick Reply: Computer codes?
