Exhaust Leak
Old 05-07-2006, 10:10 PM
Elwood4u
Elwood4u's Avatar
Default Exhaust Leak
K i just put on my o/r x pipe and I have a couple exhaust leaks, is there anything that i can do myself to fix them? Or do i have to bring it to an exhaust shop?
Elwood4u is offline
Old 05-07-2006, 10:14 PM
mustang_montana
mustang_montana's Avatar
Default RE: Exhaust Leak
where are they comming from? commonly the passenger side header to midpipe flange leaks, just need a new gasket or tighten it up. also sometimes when moving your exhaust around you may pop off spot welds on your catback, you can use jb weld to stop those type of leaks (they are gaps that are a result of the clamp design). also just check over all your bolts make sure everything is tight.
mustang_montana is offline
Old 05-07-2006, 10:16 PM
mustangGTdude1031
mustangGTdude1031's Avatar
ORIGINAL: mustang_montana
Yup Yup. Couldnt of said it better myself.lol
mustangGTdude1031 is offline
Old 05-07-2006, 10:46 PM
Elwood4u
Elwood4u's Avatar
Everything is tight, i just put the mid pipe on and there were 4 leaks, 2 coming from the header flange with brand new gaskets. And 2 where the midpipe bends down into the X.
Anything else?
Elwood4u is offline
Old 05-07-2006, 11:55 PM
0ur04GT
0ur04GT's Avatar
Make sure there is only one gasket on the pass. side. You will not get a good seal if there is 2 or any pieces of the old one there. If the leaks at the x are from the welds, I would have a shop reweld it. That would be cheap and a sure fix for those leaks.
0ur04GT is offline
Old 05-07-2006, 11:58 PM
Rusmisel01GT
Rusmisel01GT's Avatar
When me and my freind hooked up his exaust we misthreaded 1 bolt and it was just enough to give it a leak, i would make sure you didnt misthread any bolts. But thats all i can think of.
Rusmisel01GT is offline
Old 05-08-2006, 02:32 AM
monkeydude3
monkeydude3's Avatar
just crank everything down tight. When I bolted my stock ([:@][:@][:@]) midpipe back in, the passenger side to the manifold leaked. Hence I left it on jack stands for this reason. Shut it off, i cranked down those two nuts and restarted, tada no leak!
monkeydude3 is offline
Old 05-08-2006, 04:00 AM
JT76
Moderator
JT76's Avatar
I have two pretty bad exhaust leaks also. Where the midpipe meets the Catback on my SLP X/Borla combo. There is a clamp on each pipe where the X meets the CB. I have tightened them down as far as they can go and they still leak water at a pretty good rate, any advice
JT76 is offline
Old 05-08-2006, 04:13 AM
monkeydude3
well, un bolt them, then on the contacting surfaces put some of that exhaust muffler mender paste... it works almost like RTV and should seal it up fine. if you ever take it apart, it will just crumble off. I have used that before in cases like this and it has worked.
Old 05-08-2006, 04:30 AM
JT76
Moderator
JT76's Avatar
thanks man i will give it a try tomarrow, u can just pick this stuff up at like autozone right? whats the brand name of it?
JT76 is offline
Quick Reply: Exhaust Leak
