oil leak need help
Old 05-08-2006, 12:51 AM
doughboy4.6
doughboy4.6's Avatar
Default oil leak need help
Ok I have a oil leak that i cant kick I was think it was from the cam covers so i changed them now I think it may be from the crank?I have steeda pullies anyone know about this oil leak after pullies?any input may help
doughboy4.6 is offline
Old 05-08-2006, 02:04 AM
bryanec
bryanec's Avatar
Default RE: oil leak need help
https://mustangforums.com/m_1348552/tm.htm
check this thread
bryanec is offline
Old 05-08-2006, 02:14 AM
97targa
97targa's Avatar
Your pulleys have nothing to do with the oil leak.
I suggest spraying Engine-Brite or some kind of cleaner/degreaser on your block top to bottom.
this means putting your car up on ramps or stands and sraying the underside as well.
I would do this with your engine semi-warm, but not hot. let it sit there for about 5min.
Then PRESSURE WASH it all off while the car is running.
Take your car to the car wash bays late at night and do this stuff right there. No one will bother you.
Just make sure you start your engine before you start spraying and stay of these components with direct spray
Alternator
Cold Air Intake
Coil Packs
Battery..............Everthing else you should have no prob. with blasting the crap out of.
I wash my engine off every few times I wash my car.
Drive the car for a little bit then diagnose the problem. And work on a CLEAN car in the process. I hate a dirty engine.
97targa is offline
4cylinderplus2
10-09-2020 07:45 PM
bradleyb
11-27-2015 07:50 PM
jerrytubes
10-23-2015 12:11 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: oil leak need help
