Brakes
RE: Brakes
If you have to ask, you probably shouldn't do them because they are very simple.
Pretty much you take off the wheel of the brakes you want to change, remove the caliper, pads and caliper bracket, slide rotor off. Then push in cylinder of particular caliper (Open bleeder!) replace pads and rotors, put back on and then bleed each wheel and you should have great brakes.
Matt's 95 Stang
10-05-2015 07:16 AM
09-25-2015 06:42 PM
