What to do with the automatic tranny?
#21
RE: What to do with the automatic tranny?
no the 4R70 tranny is not bad, until it is compared to chevys 4L60-E, the 4R70 is good, it just sucks at preformance trans-go shift kit w/manual valve bodies, and a torque convorter will help out
#26
ORIGINAL: rudemood12
could someone please explain what we're looking at in the screenshots above? thanks!
This screen shot shows one of my tunes opened in the free Xtreme software. If you look at the top you can see the colors and numbers. The light red is the 1-2 up-shift and the dark red is the 2-1 downshift and so on. On the left grid it shows Miles per hour and the bottom grid shows throttle position. You can drag any point you want to make changes to the shift points in relation to throttle position. Same with converter lock up. The converter has a lockup clutch that locks the converter to the trans at a certain MPH in relation to throttle position. You cant make these adjustments on the unit itself, only on your PC including timing, rear gear and other stuff.
#27
I ask simply because I just installed a 2,800 stall torque converter in my practically stock 96gt.
My tranny was shot and during the rebuil I asked my mechanic for a different converter he said 2,400 or 2,800 stall.
I said 2,800 but I have no bought a tranny cooler or a shift kit yet. I just don't want it to drive like ****.
treesloth
09-28-2015 07:03 AM
