New Idle video
Old 05-23-2006, 04:38 AM
IWinULose
IWinULose's Avatar
Default RE: New Idle video
ORIGINAL: rbstang
howd you set the idle so high?
HIGH??! 800 is low...
IWinULose is offline
Old 05-23-2006, 05:10 AM
rbstang
rbstang's Avatar
mine idles at 600...
rbstang is offline
Old 05-23-2006, 12:03 PM
V8Cody
V8Cody's Avatar
You might want to get that checked out... Stock I believe mine idles at 1100.
V8Cody is offline
Old 05-23-2006, 07:05 PM
luckymckay21
luckymckay21's Avatar
ORIGINAL: rbstang
Before my cam install, mine would idle at 600 too. Now it is at 800 to 900
luckymckay21 is offline
Old 05-23-2006, 07:15 PM
wwmost
wwmost's Avatar
edit: sounds real nice. peaple told me not to get stage 2's with a blower unless it was the blower cam. how is it? does it really matter if its a n/a cam or a blower cam?
wwmost is offline
Old 05-23-2006, 08:32 PM
03sonicgt
03sonicgt's Avatar
Souns sick man, how noticeable is the car at say a stop light?? Is it only noticeable directly behind the car??
03sonicgt is offline
Old 05-23-2006, 09:03 PM
Sebski
Sebski's Avatar
Sick buzz, sounds better than alot of x piped cars i heard... i have magnaflows if i got o/r x's would i get a similiar sound or is it better to get o/r h
Sebski is offline
Old 05-23-2006, 09:05 PM
rbstang
rbstang's Avatar
ORIGINAL: V8Cody
maybe on 1st start up. once it hits operating temperature you should be idling at 600-700
rbstang is offline
Old 05-23-2006, 09:36 PM
2000GT4.6
2000GT4.6's Avatar
ORIGINAL: rbstang
ORIGINAL: V8Cody
The car simply won't idle at anything lower than 800. At 750 it dies and stumbles back and forth.
I let the car warm up the entire time at idle, so I have to go out and drive it, but I don't think I can even leave it at 800, prolly will have to set up to 850. If you punch it and then let out right away sometimes it hunts and tries to die.
WWmost: Stage 2 n/as are fine so long as you are still running stock shortblock power levels. If I try to go for 500+ i will have to swap out for blower cams. This has to do with building boost and overlap. I want to get a set of custom grinds after I put the shortblock in anyway though
03sonic: Its pretty noticable. It doesn't have the baffled muffler sound, or the old school camd sound (baffled once again) but it is pretty noticable.
Sebski: I have always liked the sound my X made. One difference is I do have longtubes, they changed how the car sounded as much as the X, and the X is a o/r X as well.
2000GT4.6 is offline
Old 05-23-2006, 09:44 PM
rbstang
rbstang's Avatar
i sometimes use the HEC digital tach. it says at operating temperature its idling around 680
rbstang is offline
Quick Reply: New Idle video
