New 3v heads on a 4.6?
Old 04-13-2004, 12:45 AM
Acer2428
Site Mod
Acer2428's Avatar
Default New 3v heads on a 4.6?
I believe the new '05 4.6 is still SOHC, simply w/ 3v heads giving it 300hp at the crank. Will those heads be compatible w/ the older 4.6? If so, I would seriously consider holding off my head swap until '05/'06 if I can gain that extra hp... is it possible to swap the 3v heads/valvetrain onto the older 4.6?
Acer2428 is offline
Old 04-13-2004, 01:14 AM
ryanzorz
ryanzorz's Avatar
Default RE: New 3v heads on a 4.6?
NO, I wish they would be, that would be awesome. The new 4.6 engines on the new mustangs use variable valve timing (basically like VTEC, but FORD, all companies have their versions). What it does is basically kind of like advancing your timing, it lets your engine operate more efficiently at higher RPM's.
ryanzorz is offline
Old 04-15-2004, 05:38 PM
ryanzorz
ryanzorz's Avatar
*UPDATE* Ford say you will be able to do it the the varialble valve timing will not be optional, and will be very expensive, might as well buy a cobra motor and swap it. HOpe this helps
ryanzorz is offline
Old 04-16-2004, 03:36 AM
GSXRIntensity
GSXRIntensity's Avatar
I actually read in the new 5.0 that it IS possible to install the 3V heads, BUT they are not going to bolt right on. Physically they will bolt right up, but apparently you will have to creat manifolding for the the intake, & exhaust, then make a plate to flow oil back to the cams from the front of the heads where Ford directs it to actuate variable cam timing. This article also notes that you would lose the variable cam timing functionality. This article can be found on page 88 of the June '04 issue.
GSXRIntensity is offline
Old 12-28-2007, 04:37 PM
Nichepi
Nichepi's Avatar
Any know of a thread showing step by step of installing 3v heads?
Nichepi is offline
Old 12-28-2007, 04:52 PM
Sxynerd
Sxynerd's Avatar
Hey noobie stop bringing threads back from the dead.
Sxynerd is offline
Old 12-28-2007, 05:03 PM
califas_1987
califas_1987's Avatar
Good Vulturing in action[8D]
califas_1987 is offline
Old 12-28-2007, 05:57 PM
Swamp
Swamp's Avatar
If you can't use the v tech part of themotorhow much HP do you loss? It sound like it would be better to swap a corba motor in.
Swamp is offline
Old 12-28-2007, 06:02 PM
cefiro80
cefiro80's Avatar
ORIGINAL: ryanzorz
+1
cefiro80 is offline
Old 12-28-2007, 06:41 PM
nitestalker
nitestalker's Avatar
Logan Motorsports' go and see them you can do it they make a kit it wont be that hard
nitestalker is offline
Quick Reply: New 3v heads on a 4.6?
