After riding home in a gully washer(Heavy rain) my abs light came on, also the light is on my traction lock like I have it off.But I have not tried it to find out. It is a 03 gt with auto and about 30k miles. I checked brake fluid level and it was ok. Should I disconnect battery to see if they clear or just go to auto zone and let them read codes? Have not tried hard braking but they seem fine.
Thanks for info
Russ
Yeah if the ABS light is still on, pull the battery cable off for at least 10 minutes, better 20-30. If the light doesn't reset then you've got a real problem
