Clutch Wear and Tear
I was wondering.. if your clutch feels alot lighter, and feels like its starting to grab alot quicker than usual, is that a sign of a worn down clutch? It hasnt been replaced since i got the car about 14 months ago.
RE: Clutch Wear and Tear
Its feeling lighter and gripping quicker? Thats the oppisite of clutch wear. Usually a worn clutch will feel mooshy and wont grip really well. It may also be difficult to get the car in 1st and/or reverse. These clutches are also self adjusting. Have you ever adjusted your clutch?
no, never tried adjusting, although sometimes i have experienced trouble getting it into reverse.. it denies me, so i end up having to put it into first, then into reverse for it to slide into Reverse..
Ya a lot of cars you actually need to go into a foward gear to get it into reverse. My car i just go 1-2-1-2 really fast then reverse. How does the clutch grip? Still pretty good?
yeah i guess it does still grab pretty good, i just began to realize over the past week, it became much lighter, and grabbed alot earlier. and being its an older clutch i figured maybe it could be worn.
I have to do the same thing with my car. I can't get it into reverse unless I move it forward real quick, and I just replaced my clutch. Whenever your clutch is getting worn, it will take a lot longer for it to catch and if it is real bad, whenever you push the gas hard enough your rpms will raise, but you won't spin the tires.
junior04
09-28-2015 10:53 AM
