2002 GT - Rear Suspension Rattle...
Old 06-21-2006, 09:42 PM
leon63
leon63's Avatar
Default RE: 2002 GT - Rear Suspension Rattle...
Thanks for all the great info. Regarding the bolts, do you mean lightly grease the entire bolt, including the threads? I usually apply some red loctite on the threads. Thanks again for all the helpful information!! I am going to try some things now.
Dan
2002 Mineral Grey 5-spd GT
leon63 is offline
Old 06-22-2006, 02:55 AM
leon63
leon63's Avatar
Well, the noise turned out to be the lower insulators on the rear springs. As the axle would bounce around at low speeds, I would hear clicking-popping sounds. I used some new 5/8" black rubber dishwasher hose for now. Are there better insulators out there? These FRPP C springs have a larger diameter opening on the bottom, compared to the stock ones. I might use urethane insulators, but these can be noisy, too.
Thanks for all the help!
Dan
leon63 is offline
Old 06-22-2006, 09:25 AM
GodAmGT00
GodAmGT00's Avatar
When you apply grease to the components, apply it to anything that makes metal-to-metal contact and moves/vibrates... You don't have to put a lot on, but make sure all the contact points are covered...
JT
GodAmGT00 is offline
musnicki
09-23-2015 07:11 AM
GimpyHSHS
09-18-2015 12:27 PM
09-08-2015 11:50 AM
RWHEELS
09-05-2015 03:42 PM
09-01-2015 08:16 PM
Quick Reply: 2002 GT - Rear Suspension Rattle...
