Can I fit a 275 on a 10.5 rim?
Old 06-22-2006, 04:52 PM
freefallin98
freefallin98's Avatar
Default Can I fit a 275 on a 10.5 rim?
I was wondering if I could fit a 10.5 rim on my 275's? Will the rims be too big or will they fit?
freefallin98 is offline
Old 06-22-2006, 04:55 PM
mightyb28
mightyb28's Avatar
Default RE: Can I fit a 275 on a 10.5 rim?
Have them on mine.
275 40 zr 18 Falken's.
Killer Rubber.
You can't go any wider in a 40, but if you drop to a 35 you can go to 315 or something
mightyb28 is offline
Old 06-22-2006, 04:59 PM
PushinTheLimit
PushinTheLimit's Avatar
You can check out www.tirerack.com for recommended sizes for tires to fit on the rims of your choice. Thats what I'm doing but those deffinetly should fit just fine.
PushinTheLimit is offline
Old 06-22-2006, 05:02 PM
Tellowman24
Tellowman24's Avatar
you should be able to fit alot bigger then 275 on your 10.5 rim
Tellowman24 is offline
Old 06-22-2006, 05:04 PM
JonBeast
Moderator
JonBeast's Avatar
ORIGINAL: Tellowman24
Hes asking if the tires is going to be too small. Obviously he can go bigger
Yes, a 275 will be fine...but a 315 would be a lot more meaty
JonBeast is offline
Old 06-22-2006, 05:37 PM
03sonicgt
03sonicgt's Avatar
The 275's look extremely strectched and way too small.
03sonicgt is offline
Old 06-22-2006, 06:21 PM
Flyingmau5
Flyingmau5's Avatar
ORIGINAL: JonBeast
well unfortunately going bigger means smaller wallet =(
Flyingmau5 is offline
Old 06-22-2006, 06:25 PM
sprostang
I ♥ Acer
sprostang's Avatar
ORIGINAL: freefallin98
The least you should go with a 10.5 wheel is a 285. A 275 will look stretched as said above.
sprostang is offline
Old 06-22-2006, 06:44 PM
gt96stang
gt96stang's Avatar
ORIGINAL: 03sonicgt
gt96stang is offline
Old 06-22-2006, 07:34 PM
Quickshift_02GT
Quickshift_02GT's Avatar
Stretched...yeah.
The will also FUNCTION different, which is way more important than how it looks. Of course nobody around here mentions anything but looks.
Expect handling to be worse with improper sizing and matching.
Quickshift_02GT is offline
Quick Reply: Can I fit a 275 on a 10.5 rim?
