Adjustable Cam gears
Old 06-24-2006, 07:21 PM
David_K
David_K's Avatar
Default Adjustable Cam gears
Anybody know of a company that makes adjustable cam gears for a 4v cobra
David_K is offline
Old 06-24-2006, 07:48 PM
Rantheman
Rantheman's Avatar
Default RE: Adjustable Cam gears
I think findonza does hold on
Rantheman is offline
Old 06-24-2006, 07:50 PM
Rantheman
Rantheman's Avatar
ok here you go
http://store.summitracing.com/egnsea...5&autoview=sku
Old 06-24-2006, 08:21 PM
David_K
David_K's Avatar
thank you sir.
David_K is offline
Old 06-24-2006, 11:33 PM
Rantheman
Rantheman's Avatar
your welcome
Old 06-24-2006, 11:37 PM
04BlueGT
04BlueGT's Avatar
Okay, I'll bite. Beside a little weight, why is this better than advancing the timing with a tuner or timing adjuster? I'm asking cuz I just don't know, fellas.
04BlueGT is offline
Old 06-25-2006, 12:28 AM
cobrapony27
cobrapony27's Avatar
with a hand held tuner you advance ignition timing. With adjustable cam gears you advance and retard the cam timing. If you advance it gives it more on the low end but takes alittle away from the top end. And if you retard cam timing its just opposite.
cobrapony27 is offline
Old 06-25-2006, 12:35 AM
04BlueGT
04BlueGT's Avatar
No, that part I get. It's the adjustable gears I'm curioius about. What do that offer that nothing else does?
04BlueGT is offline
Old 06-25-2006, 12:42 AM
cobrapony27
the cam sprocket is what makes it adjustable. you loosen a couple of bolts and rotate the cam clockwise or counter-clockwise a few degrees, usually no more then + or - 4 degrees but you can go to 6 but i wouldnt recomend that much.
Old 06-25-2006, 03:41 PM
David_K
David_K's Avatar
yeah i wonder if you just have to take the valve cover off to adjust them. It would be a bitch if you had to remove the timimg cover. Damn you have to pull the cover off. Well thats gonna make these cams a bitch to tune.
David_K is offline
Quick Reply: Adjustable Cam gears
