Upper and Lower CA's
My Upper and Lower Control Arm bushings are goin bad, well at least they are sqeaking anyways. I sprayed some WD-40 on them and it stopped the noise temporarily but it came back. Should I get poly bushings? and where is a good place to get them? Thanks
RE: Upper and Lower CA's
if you're goint to get poly bushings for them, you might as well replace the stock ones at the same time. I have some Grannatellis that I haven't installed yet. Other people can tell you what a good set to go with is.
