a/c problem
Old 06-27-2006, 03:10 PM
98GTpony
98GTpony's Avatar
Default a/c problem
well im not 100 percent sure if its the a/c or not... Right when i turn on the car and the a/c is on the car makes a real quick squeaky noise then when it idles the squeaky noise comes back .... then i turned off the a/c and then started the car again and there was no noise... i have no idea what it is ... Does anybody know what it might be
98GTpony is offline
Old 06-27-2006, 03:12 PM
monkeydude3
monkeydude3's Avatar
Default RE: a/c problem
how about if you leave it running with a/c on, then turn a/c off... does it go away then?
and does your a/c blow cold?
monkeydude3 is offline
Old 06-27-2006, 04:43 PM
98GTpony
98GTpony's Avatar
its not that cold... yes the noise goes away then
98GTpony is offline
Old 06-27-2006, 04:59 PM
bsteen81
bsteen81's Avatar
Get your belts checked, and you a/c pulley
bsteen81 is offline
Old 06-27-2006, 05:01 PM
98GTpony
98GTpony's Avatar
my belts are fine... could it be my a/c compressor
98GTpony is offline
Old 06-27-2006, 05:02 PM
bsteen81
bsteen81's Avatar
It could be, alot of things squeek.
bsteen81 is offline
Old 06-27-2006, 05:03 PM
bsteen81
bsteen81's Avatar
ORIGINAL: 98GTpony
When was the last time they were replaced? Is there any wear on them, they could be lined up a little off.
bsteen81 is offline
Old 06-27-2006, 05:14 PM
98GTpony
98GTpony's Avatar
all of that stuff is pretty much stock except for the belt ... what would i have to change?
98GTpony is offline
Old 06-27-2006, 07:15 PM
jmmorgan82
jmmorgan82's Avatar
i know in my first newer body silverado, i took it off-road in a bunch of mud and water, and for the next year or so, the AC pulley squeaked when the ac was off, and when the ac was on it squeaked even worse
jmmorgan82 is offline
Old 06-27-2006, 07:25 PM
98GTpony
98GTpony's Avatar
hmmmmmmmmm
98GTpony is offline
Quick Reply: a/c problem
