STEEDA CRANK PULLEY STILL FRIGGIN LEAKIN
Old 06-30-2004, 09:33 PM
04mustang
04mustang's Avatar
Default STEEDA CRANK PULLEY STILL FRIGGIN LEAKIN
MY steeda crank pulley is still leaking. we didnt put silicone sealent on the first time and the puleey was leaking around the inside of the outter most rim of the pulley. no where near the bolt. but we pulled it out put some silcone sealer on and its been about 20 miles later and its leaking agian from the same spot. what would cause the pulley to leak oil. we cant figure it out. the oil is on the outter rim does anyone know how to stop this leak. need some serious help im really frustrated. HELLLPPPPP MMEEEEE PLEEEEAAASEEE.
04mustang is offline
Old 06-30-2004, 09:47 PM
mdvaldosta
I ♥ Acer
mdvaldosta's Avatar
Default RE: STEEDA CRANK PULLEY STILL FRIGGIN LEAKIN
Did you wait at least an hour or two before you drove the car? RTV takes a couple hours to cure. You should wait at least an hour minimum, and make sure you pretty generously used the RTV (the gasket maker stuff, not the RTV designed to go with gaskets) on the keyway. I had no oil problems with mine.
mdvaldosta is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Florida Regional Chapter
09-30-2015 08:04 PM
UrS4
09-30-2015 10:13 AM
mungodrums
09-28-2015 10:54 PM
09-24-2015 09:18 PM
Quick Reply: STEEDA CRANK PULLEY STILL FRIGGIN LEAKIN
