exhaust bolts
Old 09-11-2006, 02:41 AM
crazyhorse
crazyhorse's Avatar
Default exhaust bolts
help/advice - i can not get the exhaust manifold bolts off on the passenger side- sprayed with wd40 for 2 days. i can get a socket on but i can not get them to brake loose & i do not want to brake the bolts off. this is on a stock 97 gt mustang with automatic transmission. i need your professional advice. thanks.
crazyhorse is offline
Old 09-11-2006, 02:56 AM
hotrod7687
hotrod7687's Avatar
Default RE: exhaust bolts
Get a can of PB penetrating spray. Works 10x better than wd-40
You trying to get them off at the heads, or where they connect to the mid pipe?
hotrod7687 is offline
Old 09-11-2006, 03:02 AM
crazyhorse
crazyhorse's Avatar
i am puting on a h-pipe. bolts are near the starter on passenger side. i don't want to break the bolts off, looks like it would be a BIG job to replace the bolts. thanks.
Old 09-11-2006, 03:12 AM
hotrod7687
hotrod7687's Avatar
Those are tough, took me a while to rig up enough extensions and swivels to get on them. Mine came off fairly easy, i took the PB and sprayed it on about 4 times in an hour while i was waiting for it to cool.
Old 09-15-2006, 04:41 AM
crazyhorse
crazyhorse's Avatar
any more ideas?
Old 09-15-2006, 06:26 AM
miglet
miglet's Avatar
use the extension, and use your foot on the wrench - plant urself under ur car, hold on for life and push as hard as u bloody well can.. thats how i got my driveshaft and exhaust bolts off... ur legs have like 5-8x as much power as ur arm every will :P.. do it in jerking motions - you might get lucky and break it loose without twisting the whole bolt / snapping it
if the bolts break off - you wouldnt have gotten them off to begin with - cus they'd be perma rusted together, and no penetrating spray is getting thru half an inch of rust fused metal !
miglet is offline
Old 09-15-2006, 11:31 AM
Poobs
Poobs's Avatar
Spray them, spray them, spray them or bring the job to a muffler shop. They charged me $75.00 to intall my off road H pipe.
It would be on their shoulders if they had busted the bolts so it was a good investment.
Poobs is offline
Old 09-15-2006, 11:58 AM
MustangMan528
MustangMan528's Avatar
leverage man, thats all i can say is leverage. The longer extentions you have the easier it will be. Also i'd recomment using a breaker bar since they're about 6-8 inches longer than your average 1/2 ratchet drive. lots of penetrating oil+lots of leverage=gettin them biotches off
MustangMan528 is offline
Old 09-15-2006, 11:59 AM
gt96stang
gt96stang's Avatar
Take a torch and heat the bolts up real good.
gt96stang is offline
Old 09-15-2006, 12:12 PM
StangChik
StangChik's Avatar
ya heat works great, but be careful, some penetrants are flammabe, make sure that stuff is dry
StangChik is offline
Quick Reply: exhaust bolts
