TrueFlow Inlet Pipe won't fit
Old 07-29-2004, 07:36 PM
HotWheels301
HotWheels301's Avatar
Default TrueFlow Inlet Pipe won't fit
Hi. I'm having problems with my C&L Maf system. Everything fits until you get to the throttle body, then the inlet pipe is too big. It's too big for my stock TB as well as a new Accufab 75mm I just received. Should I have gotten an adapter with the Maf kit? Any help will greatly be appreciated. BTW, I have a 2000 GT. Thanks
HotWheels301 is offline
Old 07-29-2004, 07:40 PM
04mustang
04mustang's Avatar
Default RE: TrueFlow Inlet Pipe won't fit
the blue ruber part that goes around the throttle body. there should be a smaller blue round rubber peice that goes on the inside of the inlet pipe so that it fits and then you tighten the clamp.
04mustang is offline
Old 07-29-2004, 08:25 PM
beezy
beezy's Avatar
Mine came with the blue rubber piece to fit over my TB also and after I put the blue ring over my TB the inlet pipe fit fine
beezy is offline
Old 07-31-2004, 08:55 AM
HotWheels301
Thanks guys. After sifting through the box of packing peanuts, I found the little 1" strip you spoke about. Everything fit fine. Thanks again.
Old 07-31-2004, 11:41 PM
04ShakinSteed
I ♥ Acer
04ShakinSteed's Avatar
Way to go Kevin!
04ShakinSteed is offline
col2560
09-25-2015 08:59 PM
09-24-2015 09:18 PM
trashxtrash
09-20-2015 10:49 PM
BrantleyS550
09-14-2015 04:18 PM
wawagner82
09-13-2015 09:02 AM
Quick Reply: TrueFlow Inlet Pipe won't fit
