Coolant Question
Old 11-08-2006, 09:27 PM
karlins99gt
karlins99gt's Avatar
Default Coolant Question
I just hit 70,000 mile on my 99 GT and I've noticed that the coolant seems to look a little dirty. Has anyone in here ever flushed their coolant in their stang and what all is involved in doing it? Any help appreciated.
Thanks
Karlin
karlins99gt is offline
Old 11-08-2006, 09:38 PM
ponysnake99
ponysnake99's Avatar
Default RE: Coolant Question
did mine last week
1. make sure the car is cool, and pop the drain plug to release all the coolant
2. if you need, flush the radiator (the directions are on the bottle)
3. fill it back up with atleast a 50/50 mixture of antifreeze and water, being winter, a 70 anti/ 30 water would be better
- - make sure your car is on when you fill up the radiator with heat on high to mix all old coolant still in the system
- - fill up with distilled water to prevent tap water contaminates from building up (not VITAL but its a good precaution)
ponysnake99 is offline
Old 11-08-2006, 09:54 PM
karlins99gt
thanks for the info
Old 11-08-2006, 10:02 PM
ShadowDrake
ShadowDrake's Avatar
ORIGINAL: ponysnake99
did mine last week
Good, only change I'd make is that the recommendation is no more than 10% in either direction... Unless it gets WAY below freezing, a 50/50 mix will be just fine... if the ambient temperatures get to be above 100 you'll want to add more water, if temps are getting below 0 (fahrenheit of course) you'll want to do a little more coolant instead.
ShadowDrake is offline
Dokilar
15
10-16-2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: Coolant Question
