what do i need to get 12 sec slip? have 1000 bucks!
Old 11-20-2006, 02:44 AM
ben790450
I ♥ Acer
ben790450's Avatar
Default RE: what do i need to get 12 sec slip? have 1000 bucks!
Try CUSTOM ground cams for $600 and then P&P the heads for another $600 and youll be there. $200 over budget but whats $200
ben790450 is offline
Old 11-20-2006, 02:45 AM
PerformanceRed4.6
PerformanceRed4.6's Avatar
want 12s witout doing cams
PerformanceRed4.6 is offline
Old 11-20-2006, 02:50 AM
ben790450
I ♥ Acer
ben790450's Avatar
oh then port and polish the heads and get a drap pack suspension. Loose a LOT of weight too. Everything you can get out of there.
trance565
trance565's Avatar
ORIGINAL: 2000GT4.6
Assuming full boltons means gears/exhaust/intake/pulleys with your new nittos and the cams all you should really need is the good driver mod.
exactly what he said get gears, and the best driver you know 12.9 or 12.8 ez
also, remove your spare, rear seat, maybe front sway bar if you want, aaaand hmmmm whatelse ... yea, that should do it, learn how to launch better ^^
with nittos, there is really no reason you ahvent done it, my brother got a 13.2 with timing adjuster, exhaust, intake, and 4.10 gears, add UD pulleys, and DR's he could take it to the 12's ez, this is on a 98 with an 01 motor swap.
trance565 is offline
Old 11-20-2006, 02:56 AM
ben790450
I ♥ Acer
ben790450's Avatar
ORIGINAL: trance565
ORIGINAL: 2000GT4.6
+1 yeah get that front sway bar outa there on game day and air down ur tires and get um nice and warm. Get some drag springs and tubular upper and lower control arms. And eaton rear end wouldnt hurt either. It has four clutches instead of the stock three. Well in that case a full electronic locker would be best for traction. No Trac-lock bs is like a full locker. And then off the strip just turn it off and bam you have limited slip. Plus its good for wheelin!
Old 11-20-2006, 02:57 AM
ben790450
I ♥ Acer
ben790450's Avatar
Also go get your car dyno tuned and have them throw a real evil tune on there come game day.
Old 11-20-2006, 03:02 AM
FuzzyDiceRule
FuzzyDiceRule's Avatar
ORIGINAL: trance565
ORIGINAL: 2000GT4.6
plz read the entire thread before posting, he said he has 4.10's and hasnt run with the drag tires yet.
FuzzyDiceRule is offline
Old 11-20-2006, 03:04 AM
ben790450
I ♥ Acer
ben790450's Avatar
ORIGINAL: FuzzyDiceRule
ORIGINAL: trance565
ORIGINAL: 2000GT4.6
Im telling you 4.10's and DR's the problem is going to be with the suspension. Thats gonna slow you down and you need to worry about that before you make more power.
Old 11-20-2006, 03:54 AM
trance565
trance565's Avatar
ORIGINAL: ben790450
suspension wont be a problem, not with a bolt on set up
and sorry fuzzy, i'm kina tired, i knew he had gears, but i just started typing
Old 11-20-2006, 04:27 AM
SOHCtimes2
SOHCtimes2's Avatar
Actually suspension will still greatly help him reduce his 60 foot times and reach his 12second NA goal. Some guy on these boards did a 12 pass with an O/R prochamber, welded in flows, timing adjuster, and suspension / tires.
SOHCtimes2 is offline
Quick Reply: what do i need to get 12 sec slip? have 1000 bucks!
