AUTOMATICS/HIGH STALL CONVERTER?
Old 11-23-2006, 09:26 PM
sweet99
sweet99's Avatar
Default AUTOMATICS/HIGH STALL CONVERTER?
I have been searching a good part of the day and cannot find a good high stall converter for the 4R70W. Stall required would be near 4000rpm's. The stock stall is 2800rpm's. It seems that there are converters out there but they cannot be locked in 2nd gear which is where time is taken off the 1/4. Suggestions on what has worked for you? Thanks, mark
sweet99 is offline
Old 11-23-2006, 11:08 PM
code3GT
Mustang Nazi
code3GT's Avatar
Default RE: AUTOMATICS/HIGH STALL CONVERTER?
Hard to find a good stall for an AOD. I'll look around for ya. I am doing a Powerglide on the 92 with a 4000 stall. I have been doing alot of research, so lemme see what I can find for ya.
code3GT is offline
Old 11-23-2006, 11:38 PM
sweet99
sweet99's Avatar
ORIGINAL: code3GTHard to find a good stall for an AOD. I'll look around for ya. I am doing a Powerglide on the 92 with a 4000 stall. I have been doing alot of research, so lemme see what I can find for ya.
Thanks. I found some info a bit dated but it seems that Circle D and BC Automotive are the 2 that have 4K stall converters that will lock up in 2nd gear and take the torque. 9.5" converters. Not cheap, around $900. Mark
sweet99 is offline
Old 11-24-2006, 02:29 PM
droptoppony
droptoppony's Avatar
ORIGINAL: sweet99
Thats who you want to use!!!
Darrin and Alan are very good at what they do. I'm saving now for a complete built tranny from BC.
droptoppony is offline
Old 11-24-2006, 05:52 PM
JD1969
Pro. B.S. caller outer
JD1969's Avatar
$900 is actually pretty cheap for a converter that you can lock in second.
JD1969 is offline
Old 11-24-2006, 06:05 PM
mustangman02232
mustangman02232's Avatar
stock stall is 2800[&:] i was told it was 1100
mustangman02232 is offline
Old 11-24-2006, 06:09 PM
droptoppony
ORIGINAL: mustangman02232
its closer to 2400-2500 i believe
Old 11-24-2006, 07:11 PM
sweet99
sweet99's Avatar
I thought it was 1800 but did some research and both the GT and the Marauder both have an 11.25" converter with a stall range from 2500-2800. I got my car in 2nd on a steep hill and goosed the throttle and got 2500/2600rpm's before much movement. There's a Thunderbird forum with a lot of converter info. I will get an exact price quote on monday for what I am looking for. Mark
sweet99 is offline
Old 11-24-2006, 08:52 PM
phalcrow
phalcrow's Avatar
I thought it was 1800 myself. I just bought a 2400-2600 "high stall". WTF?
phalcrow is offline
Old 11-24-2006, 09:29 PM
droptoppony
ORIGINAL: phalcrow
You should have did some research first...3200 is the minimum stall i suggest to people.
Quick Reply: AUTOMATICS/HIGH STALL CONVERTER?
