2003 GT aftermarket tach install
Old 12-12-2006, 02:40 AM
smirnoFFz
smirnoFFz's Avatar
Default 2003 GT aftermarket tach install
ok so i've got it all wired up and it all mounted where I wanted it.. but now i'm stuck on the wire that functions the tach.. which wire do I connect that to so I can get the tach functional?
smirnoFFz is offline
Old 12-12-2006, 03:37 AM
smirnoFFz
smirnoFFz's Avatar
Default RE: 2003 GT aftermarket tach install
damn.. no one? :/
Old 12-12-2006, 03:48 AM
H0SS302
H0SS302's Avatar
did you get the tach adapter? i thought it was just plug n play
H0SS302 is offline
Old 12-12-2006, 04:02 AM
smirnoFFz
smirnoFFz's Avatar
nah I didn't get a tach adapter.. and after doing a ****load of searches i'm supposing I have to have that..
Old 12-12-2006, 05:32 AM
GTowner4life
GTowner4life's Avatar
I had a 5 inch tach, you need the autometer tach adapter from jegs. It works perfectly
GTowner4life is offline
Old 12-12-2006, 10:56 AM
smirnoFFz
smirnoFFz's Avatar
I was told you didn't absolutely need it and theres a way around it.. anyone know the way around it?
Old 12-12-2006, 11:49 AM
sitnlopro99gt
sitnlopro99gt's Avatar
the tach wire is Pin #26 Green with white line and the only shiftlight you dont need a tach with is the raptor, I'm pretty sure you do need a tach adapter for the autometer shiftlight
sitnlopro99gt is offline
Old 12-12-2006, 12:27 PM
uberstang1
Chupacabra
uberstang1's Avatar
i didnt need a tach adapter, 1 wire to ingintion switch, one to 12v in fuse box, one ground, one to what i beleive is pin48 in the ecu, i may be wrong on that pin, not sure if its diff for 99+ models
uberstang1 is offline
Old 12-12-2006, 12:37 PM
smirnoFFz
smirnoFFz's Avatar
ORIGINAL: sitnlopro99gt
I have a gauge from FAZE and it says I don't have to have any of that.
Old 12-12-2006, 12:43 PM
sitnlopro99gt
ORIGINAL: smirnoFFz
then what I told you will do it thats were I tapped my raptor shiftlight
Quick Reply: 2003 GT aftermarket tach install
