Ford Predator
Ford Predator
99PowerGT,</P>
The Diablo Ford Predator is anice piece of equipment.</P>
It plugs into the diagnostic port on your vehicle to upload the performance program to your ECU. Th changes that it makes are as follow:</P>
<UL>
<LI>Advance the timing and adjusts thefuel curve</LI>
<LI>It has an adjustable rev limiter and speed limiter</LI>
<LI>Adjust speedometer for gear and/or tire diameter changes</LI>
<LI>Allows you to adjust shift points on an automatic and firm up line pressure</LI>
<LI>Can be used as a diagnotic tool (i.e. it will read the Ford ECU Diagnostic Trouble Code)</LI>[/list]
It comes with a pretty extensive user manual and is a pretty straightforward application.</P>
Streetsmart Design has a lower price than JEGS because they are a Warehouse Distributor for Diablo. Here is a link if you are interested:</P>
http://www.ssd4u.com/streetsmart_032.htm</P>
Good Luck.</P>
Ford Predator
EvilKenevil,</P>
The Predator can only be used on one vehicle. Once you upload the program to the ECU the Predator will log the ECU Serial number and vehicle VIN number. After that the Predator can only be used on the corresponding vehicle.</P>
Just a quick note. The Predator for the 1999-2003 Mustang GT is not yet available from Diablosport. I thought I should mention that after looking at "99PowerGT's" screen name.</P>
Good Luck</P>
Ford Predator
Can you adjust the timing and fuel curve through-out the rpm range or just at wot? And if the Predator for the 1999-2003 Mustang GT is not yet available from diablosport, how come you have a part number and pricing for it?</P>
Is Diablosport the one that make is or just sells them?</P>
</P>
Ford Predator
99PowerGT,</P>
The timing and the fuel curve are adjust from idle to WOT in 400 rpm increments with the Predator.</P>
Part Number and Pricing was released to the dealers early this month. They stated that part availability would be forthcoming shortly. However, they haven't released it to date.</P>
Diablosport is the manufacturer. Companies likes Streetsmart and JEGS are distributors.</P>
Superchip has a similar type tuner though I have never used it for the Mustang personally.</P>
Take Care.</P>
Ford Predator
Peck,</P>
Wedo not have any Predator Tuners for the 98 Mustang GT. 1999 is the earliest year that Diablosport intends to pick up as of now. The only thing Diablo has for that year is their Diablosport Delta Chip. You can find information on those at:</P>
Superchip has a Tuner available for your vehicle. The part number is: 1725 Ford "Max" Micro Tuner. You can find information at:</P>http://www.ssd4u.com/streetsmart_024.htm
If you are interested in one of those then please e-mail our sales staff at sales@ssd4u.com and tell them you found us on Mustangforums.com. They will then work up a better price than what is listed on the website.</P>
Have a good one.</P>
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
09-02-2015 07:54 AM
