Power windows
Old 10-15-2004, 01:50 AM
tmgreene
tmgreene's Avatar
Default Power windows
I have just bought a 02 GT vert great car , Only thing is I have a intermitent window problem on driver side . it wont go up . I almost took it to the dealer last time it happened but it started working again . maybe a piece of leaf under the contact . Buttttt i will check with you guys
Thanks Tom
tmgreene is offline
Old 10-15-2004, 04:49 AM
Acewelder99
Acewelder99's Avatar
Default RE: Power windows
check all the wiring connections there could be a loose one . or a bad ground maybe
Acewelder99 is offline
Old 10-15-2004, 09:16 AM
1{}D{}{V}{}DGT
1{}D{}{V}{}DGT's Avatar
ur window motor might be shorting out i would take it to the dealer if i was u they could fix ya right up
1{}D{}{V}{}DGT is offline
Old 10-15-2004, 10:44 AM
Chopper
Chopper's Avatar
Are you still under warranty?If so,get a work order so you will be able to show an intermittent problem and get it covered after the warranty expires.Can the window be rolled up from the drivers side,or only from the passenger side.If it stalls and won't work at all it is something closer to the window motor.Loose wire,corrosion,or maybe a bad motor.
Chopper is offline
Old 10-16-2004, 02:21 PM
tmgreene
tmgreene's Avatar
Just went to car after it sat for 2 days and windows started working , Strange it probly a short or loose wire i am some how moving
tmgreene is offline
cr620
10-03-2022 10:18 PM
jwog666
12-27-2021 08:09 PM
jrrhd73must
10-02-2015 09:17 PM
09-25-2015 06:58 PM
Quick Reply: Power windows
