help on check engine code
Old 10-21-2004, 05:44 PM
cuco32
cuco32's Avatar
Default help on check engine code
the code is P0301 Cylinder 1 misfire detected
Anyone know what it is...
spakplug?
wires?
Its a 96 gt 4.6, with fordracing wires and a K&N
thanks a lot in advance
cuco32 is offline
Old 10-21-2004, 05:52 PM
mdvaldosta
I ♥ Acer
mdvaldosta's Avatar
Default RE: help on check engine code
It could be plugs, injectors, or a false code. If you havent had a tuneup in a while, it'd be a good idea to go ahead and replace the plugs, fuel filter, and run some fuel injector cleaner through your gas tank. Sometimes even going over a bumpy road can throw a mis-fire code so I wouldn't get too worried just yet. I'd do a tuneup and reset the codes, or just reset the codes if you've recently done a tune-up. If problem persists then be worried.
mdvaldosta is offline
Old 10-21-2004, 08:38 PM
jdaniel
I ♥ Acer
jdaniel's Avatar
You can also disconnect a vacume line if you have the proper pump and run the injector cleaner straight through the injectors. Thats what I had done. I did that, changed the fuel filter, the oil and oil filter and the air filter all at once and the car ran really good that night at the track.
jdaniel is offline
Old 10-21-2004, 08:44 PM
tarpymac
tarpymac's Avatar
that happened to me about 3 months ago. i pulled the pluges and one had collasped. i just replaced all 8 and everything was great!
tarpymac is offline
Old 10-21-2004, 09:58 PM
jdaniel
I ♥ Acer
jdaniel's Avatar
HA HA!!! You could be a rapper when you grow up! LOL
jdaniel is offline
djbigskrilla
09-20-2022 01:04 AM
labudski
08-24-2015 07:23 AM
microgt
08-20-2015 07:12 AM
mweiland
08-13-2015 05:11 PM
drumhedd2005
08-13-2015 09:59 AM
Quick Reply: help on check engine code
