car starting problem
Old 03-21-2007, 05:01 AM
scubasteve22
scubasteve22's Avatar
Default car starting problem
for like 2 weeks now my car has had problems starting up. When i start it up it tries to then dies and pops a few times. The pop noises are loudest like where my lt headers meet my midpipe not so much in the engine. It usually takes like 3 times and i have to give it gas for it to fully start and run. every once in awhile it will start on its own or i have to push the pedal to the floor like 3 times and then start it and then it doesnt even always start the first time. i took it to a shop and a guy ran the diognostics test and the only other things than the o2 sensors cause the o/r h is my "cam comp sensors" or something like that i got those replaced and it started fine like 2 times and now back to the same thing. any idea what this could be and sorry for the long post just very frustrating to spend money on something and have it not do anything to fix it!?!
scubasteve22 is offline
Old 03-21-2007, 07:31 AM
NORMAN99
NORMAN99's Avatar
Default RE: car starting problem
Check your spark plugs?
NORMAN99 is offline
Old 03-21-2007, 04:40 PM
scubasteve22
nope havent checked that yet. i am new at all this so how would i go about doin that and how could i tell if one is bad? thanx
Old 03-21-2007, 04:54 PM
2002GTAUTOVERT
2002GTAUTOVERT's Avatar
you are new at this yet you have lt's?? i assume you didnt install them. +1 on the spark plugs and also the IAC valve since alot of mustang have a problem with that, and while ur near ur tb, go ahead and clean it
2002GTAUTOVERT is offline
Old 03-21-2007, 05:16 PM
Brute03
Brute03's Avatar
if a new camshaft position sensor(cps)didn't fix it then it's most likely the alternator that needs rebuilding/replacing. i think it's either the regulator or a diode in the alt. that goes bad and causes it to interfere with the signal from the cps, especialy since they are on the same harness, so have your mechanic check the alt.
Brute03 is offline
Old 03-22-2007, 07:10 AM
NORMAN99
NORMAN99's Avatar
First you will have to take off your air intake tube that connects to your thrott body (for easy access to a couple of the plugs). Disconnect the firing coil. Unscrew the firing coil (has only one screw). Pull the rubber firing coil out. Now you have this big gapping hole that leads to your spark plugs. You will need a 5/8 deep socket. I recommend you use a spark plug socket which has a rubber boot inside of it. You will be doing this sequence for all eight plugs......it is simple.
Look at the tips of the plugs. If they are black, heavily corroded,and look like ***....replace them. Also check the gaps with a feeler guage it should be between .052-.056 (got that info from the forum thanx forum). I would recommend not using the round feeler guage that looks like a huge silver dollar....it is not very accurate. That should be about it for the plug check.
NORMAN99 is offline
mstahoo
SVT Forums
08-19-2021 09:15 PM
ShaneB26154
35
03-04-2021 04:05 AM
Soldier GT
12
08-20-2015 09:42 AM
Milan Dragway
08-12-2015 03:43 PM
J.casone400
08-07-2015 08:40 PM
Quick Reply: car starting problem
