Another PI swap ?
Old 03-26-2007, 12:16 AM
96_LAstang
96_LAstang's Avatar
Default Another PI swap ?
Ok, i am about to purchase the PI swap, i was going to do a full rebuild but im just going to wait on that. My only concern is how hard is it to time after i install the new cams? I am going with stage 1's maybe 2's, but have heard i will have PTV problems with stage 2's? I want a really agressive lope.
96_LAstang is offline
Old 03-26-2007, 12:24 AM
98MustangSTL
98MustangSTL's Avatar
Default RE: Another PI swap ?
You're using the stock shortblock? I'm going with Comp 270's, and I've heard of some problems, but eveything should be cool if you degree the cams properly. I will you will be fine with stage 1..anything. Again make sure you degree them properly. Also make sure that you check prior to running the car. They are multiple ways to check PTV. If this doesn't help. Keep the questions coming then.
98MustangSTL is offline
Old 03-26-2007, 12:28 AM
96_LAstang
96_LAstang's Avatar
Yea im using stock shortblock.How do you degree cams?
Old 03-26-2007, 01:05 AM
98MustangSTL
I'm no expert on this; in fact, I haven't even doneit before. I'm piecing together what I need right now. Here's an article that gives you a pretty good idea. http://www.fordmuscle.com/archives/2...ot2V/index.php
GimpyHSHS
19
12-19-2023 01:12 PM
Bokeo
10-10-2015 08:28 PM
Matt's 95 Stang
10-05-2015 07:16 AM
guitarman376
09-30-2015 05:54 PM
UrS4
09-30-2015 10:13 AM
Quick Reply: Another PI swap ?
