Ethanol fuel
Old 03-26-2007, 04:35 PM
Yellow Fever
Yellow Fever's Avatar
Default Ethanol fuel
Does anyone know if you can use ethonal fuel in a supercharged Mustang ?[/align]The octane rating is 103.[/align]
Yellow Fever is offline
Old 03-26-2007, 05:09 PM
Red02GT
Red02GT's Avatar
Default RE: Ethanol fuel
I don't think you can use 100% Ethanol fuel on any vehicle unless the vehicle was made to take it. I know some of the new Tahoe's run on Gas and E85 Ethanol.
Red02GT is offline
Old 03-26-2007, 05:14 PM
ponysnake99
ponysnake99's Avatar
it will eat away at the rubber parts of your fuel system and requires more fuel to release the same power....not worth it
ponysnake99 is offline
Old 03-26-2007, 05:18 PM
Yellow Fever
Thanks for the help. Hey Poneysnake.What are your hp #'s ?
Old 03-26-2007, 05:29 PM
ponysnake99
not sure, car came with the p-1 and a fairly good tune, so i havnt really bothered with a dyno. After putting my own touch on the car (exhaust etc) im hoping for some good numbers, bout to find out next weekend
Old 03-26-2007, 05:30 PM
Yellow Fever
Okay,just wondering...
Old 03-26-2007, 07:36 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
Octane is only part of the equation, gallon for gallon ethanol has only about 65% of the "energy density" of gasoline so you have to squirt in a lot more of it to achieve a proper mixture--the amount needed to achieve similar power output is around 1.6 times the amount of gasoline required.[/align][/align]This is one of the things the ethanol pushers won't tell you, to travel as far as 10 gallons of gas will take you, you'll need 15-16 gallons of ethanol (E-85's a bit better but you'll still need almost 1-1/2 times as much)...[/align]
cliffyk is offline
GimpyHSHS
19
12-19-2023 01:12 PM
4cylinderplus2
10-09-2020 07:45 PM
Sixx
10-05-2015 07:36 PM
svfetter
10-05-2015 11:39 AM
mrappe
09-26-2015 10:16 AM
Quick Reply: Ethanol fuel
