Constant White Smoke.. HELP!
I got a constant stream of white smoke coming out my tails - I know white smoke is coolant but what should I check for. I'm hurtin right now guys and scared ****less - help me out. It doesn't smell too good either, that mean a cracked head?
RE: Constant White Smoke
Bet it's a blown fire ring on one of your head gaskets. Check for water in your oil (will have a milky look to the oil), Run a compression test, run a leakdown test on your cylinders, and pressure test your cooling system. If any of them our out of spec.probably have a bad head gasket. Have to pull heads, replace both gaskets, and while your at it, consider getting your heads checked and reworked at a machine shop.
It is. My friend bought a guage to do a compression test on his truck. I think it plugs into where the spark plug goes. Correct me if I'm wrong. But I'm sure a shop won't charge you much to run one.
breaking
10-02-2015 01:27 PM
