caster cambers
caster cambers
i'm looking to install the eibach pro system plus. do i really need to get cc plates? a friend of mine got 2" drop springs for his focus and he didn't get them. i know it's a different car, but i was just wondering.
thanks!
timi
thanks!
timi
RE: caster cambers
I would definitely add them to your stang. I know allot of people say you don't need them, but I disagree. First, with c/c plates, you can add more pos. caster 3.5+. This helps the car track straight/return to center and gives you more steering feel/input. The second is that when you lower , even only 1.5" the front strut piston is now lower in the strut housing...good chance of bottoming out the struts! With a quality set like MMs, you can add spacers under the plates to bring the strut mounting point close to stock specs. This will put the piston/shaft back into the proper operating range. I hope this sheds some light on using caster camber plates.[/align]
Casey
Casey
RE: caster cambers
ORIGINAL: yelw02GT
i have the pro kit and you WILL need them belive me, ive gone threw a pair of tires every 4 months for the past year and i finally just ordered my caster camber plates
