Oil Pressure
Old 03-26-2003, 02:11 PM
toren302
toren302's Avatar
Default Oil Pressure
I have a 1968 Mustang Coupe, with a 1978 351w. I just finshed the engine swap not to long ago, and it is burning oil at or above 2000rpm. I also have verry low oil pressure. Any help would be great.
Thanks
toren302 is offline
Old 03-28-2003, 11:34 PM
Justang46L
Justang46L's Avatar
i'm tempted to think that your piston rings are worn out. if the engine has alot of miles on it, it's a good bet. as for oil pressure, make sure you're using the right grade of oil and that you're oil pump isn't worn out.
Justang46L is offline
svfetter
10-05-2015 11:39 AM
88 orangepeel notch
10-05-2015 09:03 AM
wraith777
09-28-2015 10:49 AM
ccdguy
09-19-2015 05:20 PM
SteelerNation82
09-16-2015 07:11 AM
Quick Reply: Oil Pressure
