help please! fast!
Old 09-10-2007, 08:20 AM
BlackMage
BlackMage's Avatar
Default RE: help please! fast!
if ur shredding belts its probably not the belt just being low quality, there is a different problem. Make sure all your pulleys are good, and i saw someone said soemthing about the idler puller, that has a tendency to wear out and tilt off center and make belts wear fast. also make sure your tensioner is still good too, same thing as the idler puller
BlackMage is offline
Old 09-10-2007, 08:22 AM
4.698GT
4.698GT's Avatar
Part Number for the Gatorback belt should be 4060106, if i remember correctly from work.
edit: its 40601060
4.698GT is offline
Old 09-10-2007, 10:00 AM
2000GT4.6
2000GT4.6's Avatar
ORIGINAL: militaryjag05
+1 Gatorback. Just google 106 gatorback belt. That should find you a good belt that better last a long time.
+1 WTF an hour and a half???? i think he is sleeping during the first oh i would say hour and 10 minutes then takes a cigarette break half way through it.
+1 gatorback ftw
2000GT4.6 is offline
Old 09-10-2007, 04:35 PM
1BadSonicBlue02GT
1BadSonicBlue02GT's Avatar
i am gettin a weird rattling noise coming from what sounds like the a/c pulley, but from lookin nothing seems to be out of the ordinary.
The Reason i believe the belt to be starting to tear is because i decided belt dressing would help the belt from slipping,(NOOBIE MISTAKE!!!) when in fact it made it worse, i was told to use carburetor cleaner or brake cleaner on the pulleys and belt to clean them off and it seemed to be helping. But i think that it was slipping so bad before that it ruined it and know its starting to break down
1BadSonicBlue02GT is offline
Old 09-10-2007, 04:45 PM
1BadSonicBlue02GT
Is this the style everyone is referring to?
Old 09-10-2007, 05:05 PM
8banger
8banger's Avatar
Make sure you Belt tensioner isnt't ready to burst apart...they sometimes rattle when their about to pop..and belt shredding is also an indication...along with a squealing belt...Look and see if its bowed out from center....
8banger is offline
Old 09-10-2007, 09:31 PM
1BadSonicBlue02GT
bump
Old 09-11-2007, 06:57 AM
mariotraci
mariotraci's Avatar
Gatorback i s sold at autozone
ftw-belt dressing is only to be used on v-belts nota serpintine belt
pretty sure is says it right on the can.
mariotraci is offline
Bokeo
10-10-2015 08:28 PM
stealth_GT
The Racers Bench
09-22-2015 02:19 PM
ctgreddy
09-20-2015 08:35 PM
09-16-2015 07:53 PM
Quick Reply: help please! fast!
