what gears to run with nitrous
RE: what gears to run with nitrous
ORIGINAL: 01snake
4.30's + 150 shot this winter = ~460 RWHP
i will have to get some et streets because i will rip any other d/r up
ORIGINAL: 2002GTAUTOVERT
do cams help with a nitrous shot? can you run a generic blower cam or do you need a custom grind?
ORIGINAL: 01snake
And for the gears, 4:10's would work well w/ the power you'll be producing; but your tires won't like them too much. 3:73's would be great and won't spin up the tires too bad, but the 4:10's would love the power you'd be making. Make sure you get some Mickey T's if you go 4:10's...
4.10's work well but you may run out of gear at the track if you have a 5 speed and the factory rev limiter. I had to step up to a taller tire because I was hitting the rev limiter at 110mph beofre I reached the finish line.
Damn, 110 maxes it out in 5th? I didn't realize that... I just had 4.10's installed today, but I have to wait to install my new tranny before I can witness their true potential. What tire did you end up running to compensate?
well i dont want to be running out of gear so i guess i will try the 3.73 with this gear how fast am i goin to half to shift out of first what im trying to say is am i goin to redline real fast are not
ORIGINAL: 01GT4.6
ORIGINAL: JayC
That's because your tight *** never got a tune
ORIGINAL: 01GT4.6
and no you won't max out at 110mph in 5th, but you don't want to spray in 5th either. 110mph is about all you'll get out of 4th.
