Replacing axle question - 31 spline
Old 04-08-2008, 08:16 PM
  #21
mustang430
mustang430's Avatar
Default RE: Replacing axle question - 31 spline
alright, i have a 2002 GT and this is the following i just purchased and am installing this week.
-FRPP 31 spline trac-loc with carbon clutches
-Moser 31 spline axles
-FRPP 3.73 gears
-FRPP complete install kit with all bearings and seals.
mustang430 is offline
Old 04-08-2008, 08:22 PM
  #22
2abouAziza
2abouAziza's Avatar
where did you buy all this stuff from and how much is it costing?
thxs
2abouAziza is offline
Old 04-09-2008, 12:45 PM
  #23
2abouAziza
2abouAziza's Avatar
If i change my stock spline differential to 31 instead of 28 then i have to change out the axel and make it 31 spline also. Now do any modifications take place or do i just replace the differential with a 31 spline differential, add a ring and pinion, add the seals and bearings of the pinion, add the 31 spline axel and axle seals and bearings? Are the2 bearings and2 sealsof the 28 spline axel the same as 31 spline axel or are their special or different kinds?
thank you
Old 04-09-2008, 12:50 PM
  #24
2abouAziza
2abouAziza's Avatar
thank you
Diode Dynamics
28
05-26-2022 12:02 PM
Urambo Tauro
09-07-2015 12:47 PM
Boostaddict
Lethal Performance
08-13-2015 01:57 PM
ccwebb
08-11-2015 06:47 PM
Mnuckolls
08-09-2015 08:54 AM
Quick Reply: Replacing axle question - 31 spline
