Pi Swap
Old 12-07-2007, 09:44 PM
jEEd
I ♥ Acer
jEEd's Avatar
Default RE: Pi Swap
i've already told ya what you needed via myspace[8D]
goodluck w/ it! and maybe you'll beat my 14hours of labor (including 2hour trips to shop to get some bolts / warehouses for oil cap etc..) aha
jEEd is offline
Old 12-08-2007, 01:39 AM
jst98gtmustang
jst98gtmustang's Avatar
Default RE: Pi Swap
ORIGINAL: jEEd
I post this before the myspace stuff [:-]
jst98gtmustang is offline
Old 12-08-2007, 02:23 AM
Yellow_stang
Yellow_stang's Avatar
Default RE: Pi Swap
Hey jEEdim looking forward to doing a pi swap on my 98 Gt, i was wondering since you alsolive in california if we are able to pass smog checks with the pi swap... thanks
Yellow_stang is offline
Old 12-08-2007, 12:00 PM
jEEd
I ♥ Acer
jEEd's Avatar
Default RE: Pi Swap
ORIGINAL: Yellow_stang
easily! i passed w/ flying colors literally a couple months back and i have my sheet scanned to my computer if you wanna see. just make sure you find a guy that'll waive the whole "inspection part" where they check if you have aftermarket parts and verify the carbs/ epa#'s n bs... because i went to a random smog shop at first and failed instantly... lol then i went to my local perforamnce shop and recommended me to this other guy thats a mustang kinda guy too :]
jEEd is offline
jEEd
I ♥ Acer
jEEd's Avatar
Default RE: Pi Swap
ORIGINAL: jst98gtmustang
ORIGINAL: jEEd
haha oh wells [8D]
jEEd is offline
Old 12-08-2007, 12:15 PM
Nitti00GT
Nitti00GT's Avatar
Default RE: Pi Swap
ORIGINAL: stangdriver2007
ORIGINAL: EaZy DuZ iT
how much does it cost for a PI swap?
why are you asking? you have a 2004 it already has PI heads. if you really want to do it for power do some cams while ur in there and get the pi heads ported. at home i have some ported pi heads with comp 274H cams beehive valve springs and stainless steel proflow valves the cam gear with arp cam gear bolts. all that cost me 1075. thats not bad considering the heads have all new seals new valves new everything and have been level checked and pressure checked. the cams do have 10k miles on them but look brand new. just a pi swap though without cams and porting and all that will run about 1200-1500 i think heads can be bought from summit with cams i think for about 350 each i think and a manifold from ebay for 175 shipped. u will need a cylinder head changing kit or u can buy all the things seperate but the changing kit is 117 from summit gaskets and head bolts and more. i would personally get cometics head gaskets for it they are about 50 bucks each but are very good and they are OEM. they do have different thicknesses if u want to lower ur compression or not but if u wont go F/I get the stock thickness it will put u at 10.5:1 compression. that will gain more power than lower compression. also with the 10.5:1 nitrous is not a problem if you want to do that down the road. 10.5:1 is a little high to run boost. i wouldnt do over 6lbs with that compression and 6lbs wont do a whole lot, but u will see a nice gain still. with my set up with these heads and cams and full exhaust im told i will be about 350+ hp to the wheels. make sure u get a full intake like a cold air and tb and plenum it will def help in the gains in power. i have a JLT full intake at home, bbk 75mm tb and trick flow plenum. if u do all this with the cams and everything with full exhaust u will see the same gains as me about 350 to he wheels thats cheaper and better gains that a supercharger. all thats will run you about 2200 i think save 1000 or a lil more than a supercharger with better gains sounds better to me. you might have to get a new fuel pump with this setup. i have not had mine done yet but the injectors will be fine but i hear from the shop the fuel pump might not have enough flow. hope this helps
Compression is that high after a PI swap? Damn. Also those numbers are with the Comp cam and the ported PI heads right?
Nitti00GT is offline
Old 12-09-2007, 02:03 AM
Yellow_stang
Default RE: Pi Swap
damn that feels gud knowing that it will pass smog, that was the only thing that worried me since its my daily driver...lol thanks
GimpyHSHS
19
12-19-2023 01:12 PM
Bokeo
10-10-2015 08:28 PM
Matt's 95 Stang
10-05-2015 07:16 AM
guitarman376
09-30-2015 05:54 PM
UrS4
09-30-2015 10:13 AM
Quick Reply: Pi Swap
