Guess what I did...
Old 09-30-2003, 03:21 PM
GSXRIntensity
GSXRIntensity's Avatar
Default Guess what I did...
<FONT face="verdana, arial, helvetica" size=2>I FEAR NO GEAR...4.10's were ordered today!!!! <IMG src=smileys/smiley15.gif border="0">
So, now here's the question...RPM outlet had an asterik stating that I needed a modified cross shaft w/anything lower than a 3.73, but I ordered from Dugan-Racing, &amp; he told me that he was not certain as to why I needed a modified cross shaft. Can anybody clarifiy this for me? Also,...is there a better quality fluid that I should use now w/this gear? Thanks ahead of time</FONT>
GSXRIntensity is offline
Old 09-30-2003, 04:34 PM
mdvaldosta
I ♥ Acer
mdvaldosta's Avatar
I dunno, never heard of that, just slap em in an be sure you've got a good contact patch and let em ride!</P>
mdvaldosta is offline
Old 09-30-2003, 06:00 PM
Snydaleid
Snydaleid's Avatar
I just use the OEM fluid with a good friction modifier. Worked great for me. </P>
I have 3.73s so I have no idea about that shaft.</P><edited><editID>Snydaleid</editID><editDate>37894.6699768519</editDate></edited>
Snydaleid is offline
Old 10-01-2003, 03:02 AM
USAMuscle
USAMuscle's Avatar
Synthetics are always better than OEM...if you want to free up some available HP go with synthetics. Saw like a 10-15 HP gain in a 4.6 'stang when some guys used synthetic gear and tranny fluid. It's just free HP. Plus synthetics have a longer lifespan than petrol.
USAMuscle is offline
Old 10-01-2003, 03:39 AM
2002 Stang GT
2002 Stang GT's Avatar
10-15 HP !!!!???
2002 Stang GT is offline
Old 10-01-2003, 04:04 AM
Snydaleid
Snydaleid's Avatar
</P>
Where's the BS flag when you need it??</P>
Old 10-01-2003, 09:29 AM
nostang
nostang's Avatar
Yes I have seen dyno test in magazines that get 10-15hp by going with synthetics in the trans and rear axle.You may need a different cross shaft with 4.10 gears because the ring gear is thicker and may hit the cross shaft,some of the cross shafts that I have seen have one side kind of ground off to get the clearance you need to slip the shaft out so you can push the axles in to get the c-clips off.
nostang is offline
Old 10-01-2003, 06:03 PM
Dan04COBRA
Super Moderator
Dan04COBRA's Avatar
That is no bulls**t.</P>
If you do synthetic, engine,tranny &amp; rear gear oil you can see upwards of 10-20hp gains.</P>
Mind you, you need to have a tranny flushed correctly if you want to use synthetic, an entire synthetic change could run about 300-400 bucks.</P>
Dan04COBRA is offline
Old 10-01-2003, 10:06 PM
USAMuscle
USAMuscle's Avatar
</P>
</P>
Dude do some research before you criticize what I say. It may not seem possible, but I guarantee you it is.</P>
Old 10-01-2003, 11:42 PM
Monch
Monch's Avatar
Dan, I take it a "correct" tranny flush isn't simply a drain and refill, could you elaborate a bit so adiy guy like myself could do it? I would feel a lot better about myself if i could free 20 horses from captivity.</P>
Monch is offline
Quick Reply: Guess what I did...
