Need help... H or X pipe?
Old 01-16-2008, 11:37 PM
mikemc04gt
mikemc04gt's Avatar
Default Need help... H or X pipe?
A little background...I have a '04 GT that is stock except I had the factory mufflers replaced with Flowmaster 40's. It sounds pretty good, but I want it louder. The car is under warranty so I can't remove the cats. I know the car has a factory H behind the cats, will adding an aftermarket H or X and leaving the rest of exhaust as is make the car obviously louder? I don't really want to install a whole new cat back system at this time.Thanks in advance.
mikemc04gt is offline
Old 01-17-2008, 12:35 AM
vertmustang98gt
vertmustang98gt's Avatar
Default RE: Need help... H or X pipe?
Puttin a h or x pipe on a car will make obviously louder. Although Ford will probably void your warranty unless you know someone that can let you slide by. I wouldn't recommend puttina mid pipe on the car if you want too keep the warranty because you can't leave the stock cats on with thenew pipe. It will make the car sound mean though, an h pipe will give the car a deeper tone with the flowmasters, but if youwant a raspier tone you can go with an x pipe.
vertmustang98gt is offline
Old 01-17-2008, 01:26 AM
MU71L4710N
MU71L4710N's Avatar
just put the stock one back on if you ever have to go in for warranty work...its not rocket science.
MU71L4710N is offline
Old 01-17-2008, 06:14 AM
IanJK46conv
IanJK46conv's Avatar
anyone have sound clips of a Pypes catted x pipe and catback? Just got mine in the mail, can't wait til spring to hear it. Also, jba or bbk headers? I'm leaning toward ceramic jba.
IanJK46conv is offline
Old 01-17-2008, 12:49 PM
rainydayracing
rainydayracing's Avatar
I like the H with flow's, but everyone has their own opinion. Check out the clips, and see what you like the best.
rainydayracing is offline
Old 01-17-2008, 12:56 PM
boduke0220
boduke0220's Avatar
my neighbor has a 99 GT and it has 4 cats on it. they took the 2 front ones off and it sounds MEAN!!! i have flows on mine and so does he and his sounds so much better.
and it will still pass emissions i believe. but that will vid the warrenty
boduke0220 is offline
Old 01-17-2008, 04:36 PM
mikemc04gt
mikemc04gt's Avatar
Will removing the stock H and cats cause the computer to throw a code or affect the way the car runs or fuel economy?
Old 01-17-2008, 04:49 PM
mvr
mvr's Avatar
ORIGINAL: mikemc04gt
yes removing the cats will throw a code from the rear 02's whos job it is to make sure the cats are doing there job. and i ran with that code on for a month, didnt notice any difference accept that freakin anoying engine light. and removing the cats will increase your mpg a tad.
mvr is offline
Old 01-17-2008, 09:03 PM
Mustang 03 GT
Mustang 03 GT's Avatar
With Flow's go with the h-pipe. I bought a summit o/r h-pipe with my flowmaster cat back exhuast and it sounds mean!! I also kept my stock mid pipe w/cats just in case I needed it for state inspection.
Mustang 03 GT is offline
Old 01-17-2008, 10:00 PM
CarolinaCobras
CarolinaCobras's Avatar
X pipes.
end.
CarolinaCobras is offline
Quick Reply: Need help... H or X pipe?
