2000GT 5W20 or 5W30
Old 02-28-2008, 08:18 AM
MJH78
MJH78's Avatar
Default 2000GT 5W20 or 5W30
Ok my owner's manuals says to use 5W30, but it seems like most everyone is using 5W20 motor oil. Did Ford publish one thing int he manual and then later change the recommendation to
5W20? Seems like I remember this being the case with gear oil too. The manual says one thing and then they come back and change it to something else.
MJH78 is offline
Old 02-28-2008, 09:10 AM
MustangMan00
MustangMan00's Avatar
Default RE: 2000GT 5W20 or 5W30
i beleive 01-04 they changed it to 5w20...i got a 2000 and ive always used 5w30
i used 5w20 once by mistake with no problems tho
you better be using Mobil 1 synthetic either way tho
MustangMan00 is offline
Old 02-28-2008, 09:16 AM
Brute03
Brute03's Avatar
mine says 5W20 on the cap, but i run 5W30 anyway.... it wont hurt anything.
as for the gear oil, i know they changed it to 75W140 in 02 or 03
Brute03 is offline
Old 02-28-2008, 09:28 AM
Sxynerd
Sxynerd's Avatar
Either is fine. I run 5w30 RP only because thats what my parts store carries in stock.
Sxynerd is offline
Old 02-28-2008, 09:31 AM
MJH78
MJH78's Avatar
ORIGINAL: MustangMan00
Nope...AMSOIL
MJH78 is offline
Old 02-28-2008, 10:31 AM
bt1288
bt1288's Avatar
They switched to a lighter weight to try and squeeze a little more mpg's out of it.
bt1288 is offline
Old 02-28-2008, 04:47 PM
jefster411
jefster411's Avatar
I run 5w20 Mobil 1. Never had any problems.
jefster411 is offline
Old 02-28-2008, 05:06 PM
Kmoran81
Kmoran81's Avatar
It says right on my oil cap 5W20. I use Castrol Synthetic which is what my owners manual says to use
Kmoran81 is offline
Old 02-28-2008, 07:08 PM
balbert
balbert's Avatar
i work as a mobil rep, and ford started using 5w20 in 2000 on some models, and all in 2001. but ford did not change any internals for the oil switch. i have a 2000 gt and it calls for 5w30 under the hood in the catylsit. also the 5w20 is used to lower emisions.
balbert is offline
Old 02-28-2008, 08:16 PM
lizzyfan
Underboss
lizzyfan's Avatar
ORIGINAL: sxynerd
Either is fine.
Yep
lizzyfan is offline
Quick Reply: 2000GT 5W20 or 5W30
