swapped faster?
swapped faster?
Ok im kind of scratching my head here. Wondering is a 98 gt with a pi swap done going to outrun a edge? Say both coupe, 5 speeds ,stock, just the 98 has the pi swap? Ive got a 98 and im about to do the conversion. Ive got a buddy with an 01 gt, he thinks he can still outrun me when im done is this true?
RE: swapped faster?
no, technically if everything is 100% the same you will take him because PI swap bumps our compression up, which makes more power. but it's not much of an advantage so it's still very much of a drivers race. if you two are both about equal i'd give the win to you, but it wouldn't be by very much.
RE: swapped faster?
I've seen PI head swappers with good tunes make 255rwhp but never any more. I made 261-265 NA on 3 different dynos and I hadn't ever been beat by a PI swapped SN. I'm a fair driver. I have a full PI engine and even still have my stock 2.73 gears. My tuner uses SCT.
RE: swapped faster?
ORIGINAL: sxynerd
RE: swapped faster?
when you pi swap like said your compression ratio is higher than ours so you make a few more ponies stock for stock. donno wut gears your car has though but if they the same as the edges then it will be a drivers race but you will still have SLIGHTLY more power.
RE: swapped faster?
I'm making 260.7 rwhp and 302.0 rwtq with aPI swap, Flowmaster exhuast, BBK h-pipe, 70 mm tb, and SCT tune. I've raced a '97 Cobra (exhaust and 3.55's) and '00 GT (exhaust and intake) and I was dead even with both of them. I don't know what kind of driver's they were, but I'm not the best.
Matt's 95 Stang
10-05-2015 07:16 AM
