Engine Swap
Old 03-14-2008, 08:45 PM
bikemikeb
bikemikeb's Avatar
Default Engine Swap
Ok, so i took my mustang to ford, and apprently i have a lower end rod knock. sad for me. they say to do an engine replacement and thats what im gonna do. How hard is it to swap an OE engine for an OE engine? Shouldn't it be pretty much plug and drive? Also, i have an odd situation when i first start my car. the oil pressure seems to be zero. it has oil and runs fine. i don't really care if it blows right now cause i need to replace anyways. what would cause the guage not to work right or if the guage is fine, what would cause it not to get oil pressure besides the oil pump?
2000 Mustang GT
Pro 5.0
3.73
Lowering Kit
315's out back (Nitto 555R)
Cat Back w/ 2 Chamber Flows
17 Inch Torque Thrust's
bikemikeb is offline
Old 03-14-2008, 08:53 PM
BraMas
BraMas's Avatar
Default RE: Engine Swap
Yes swapping another 4.6 into your car is just a plug in and drive situation.
When you say no oil presure do mean for a second there is none (normal) or for a minute there is none (not Normal)
BraMas is offline
Old 03-14-2008, 10:11 PM
bikemikeb
bikemikeb's Avatar
It takes about 1 to 3 minutes for the oil pressure to kick in. when it does though, i have plenty.
Old 03-14-2008, 11:11 PM
Sxynerd
Sxynerd's Avatar
Replace your OIl Pressure sending unit. Then recheck. I would however not let the engine run for any amount of time without oil pressure.
Sxynerd is offline
Old 03-15-2008, 01:13 PM
bikemikeb
bikemikeb's Avatar
Normally I wouldn't either, but im to the point where i want this engine to blow. the knock has caused a loss in power, mpg, and its damned embarassing to drive with a noise like that under your hood. it makes it not possible to pick up chicks. hahaha.
Granatelli Sales
01-20-2020 12:34 AM
Nick Oliver
10-17-2018 04:22 AM
97SN95GT
09-13-2015 09:45 PM
mdj89
09-06-2015 11:08 PM
zachary1988
09-04-2015 03:04 PM
Quick Reply: Engine Swap
