01 4v vs 03-04 4v Heads
Old 03-17-2008, 08:17 PM
silverstang1996
silverstang1996's Avatar
Default RE: 01 4v vs 03-04 4v Heads
ORIGINAL: lizzyfan
ORIGINAL: silverstang1996
01 heads don't flow as well as the 03/04 heads, they aren't that much behind, but its just a little difference
+1, 03/04>96-98>99/01
i don't know if i'd go as far as saying 96-98 are better than 99-01. I think the early C series are a little better than the B series, but as far as P&P then comparing them, the B series would probably do better, they are a better head for race application.
silverstang1996 is offline
Old 03-17-2008, 09:18 PM
Fobra
Banned
Fobra's Avatar
the cobra heads and c heads are essentially identical in flow rate, the cobra heads are little more setup for FI, I believe the springs are a little different as well, basically imo you can think of the c heads and 03 04 heads sinomously, but the B heads stock arn't great, but with a race port and high performance valve train all 3 series of heads perform essentially the same
Fobra is offline
Old 03-17-2008, 09:26 PM
silverstang1996
ORIGINAL: Darkcrime
That's crazy to think about....
If the 03/04 heads are better, that means the stock supercharger makesLESS THAN65 more flywheel hp than the 99/01 cobra's. Correct?
I have been told they underrated the 03-04 termies to where they are at around 425 or so flywheel but still....
Is there anyone that has info on this? flow charts or anything... Im curious to see if they are the same heads, and if not, how much more one flows over the other (if that makes sense)
my SHM book is in the garage but i think on the intake side, all three heads flowed within 30CFM , on the exhaust side they flowed within 40CFM of each other.
mustangman36578
22
02-02-2009 01:33 AM
cmpwiz
24
04-07-2008 11:23 PM
NeoTokyo
06-26-2007 09:34 PM
JKBMKIII
04-27-2007 12:37 AM
NeoTokyo
04-16-2007 09:42 PM
Quick Reply: 01 4v vs 03-04 4v Heads
