Another S/C Thread...
Old 03-30-2008, 09:20 PM
40thGTKB
40thGTKB's Avatar
Default Another S/C Thread...
The time has come for the imfamous KB.
My motor just hit 25k miles. Will it be safe to run a constant 6-8 PSI boost without worrying about blowing the engine.. if it is a DD?
Also, If I only plan to run 6-8 psi of boost, do I need to purchase an intercooler? Not unless I plan on doing a few more psi of boost correct?
The kit I plan on buying is the TS1000-99 for ~$3899. It comes with all the needed components such as the manifold, hoses, belts, etc. Other than the kit, and new spark plugs, do I need anything else?
Is there anything else I should know before doing this?
40thGTKB is offline
Old 03-30-2008, 09:44 PM
djay
djay's Avatar
Default RE: Another S/C Thread...
You're right, 6-8 should be fine on the stock block, at 25K miles I would not be worrying about blowing your engine on 6-8 PSI (assuming you got a decent tune). You are going to need it dyno tuned, that's for sure.
djay is offline
Old 03-30-2008, 10:03 PM
blowngt2419
blowngt2419's Avatar
yea don't be worried about your engine untill your in the 400's then you can start worrying about your rods and stuff
blowngt2419 is offline
Old 03-30-2008, 11:40 PM
40thGTKB
40thGTKB's Avatar
what about stock fuel pump and injectors, are they sufficient enough for a S/C?
40thGTKB is offline
Old 03-31-2008, 12:06 AM
Sap
Sap's Avatar
No, both need to be upgraded. Do a search on this subject and I'm certain you will get tons of information.
ORIGINAL: 40thGTKB
Sap is offline
Old 03-31-2008, 08:19 AM
cahtr6
cahtr6's Avatar
If you are buying the kit from K/B it comes with bigger injectors and boost a pump.
cahtr6 is offline
Old 03-31-2008, 09:33 AM
fausty
fausty's Avatar
you need bigger injectors and better fuel pump(svt pump)also you should consider intercooling it ,those blowers make alot of heat and would run better with an intercooler.make sure you get a good tune as well.
fausty is offline
Old 03-31-2008, 10:43 AM
40thGTKB
40thGTKB's Avatar
Ok. cahtr6 is correct. The kit does include the bigger injectors and boost-a-pump. What would be the advantages of buying a intercooler now and only running 6-8 lbs of boost?
40thGTKB is offline
Old 03-31-2008, 10:46 AM
1999 GT
1999 GT's Avatar
yea def 25k is nothin- you'll be fine
1999 GT is offline
Old 03-31-2008, 02:35 PM
djb1187
djb1187's Avatar
I got the intercooled kit and i would definatly recommend that. It drastically reduces intake temperature and plus you will net a nice gain in horses with the ability to run more boost without detonation. The kit comes complete. The only thing youll have to buy, or I had to buy...was 3 gallons on anti-freeze, spark plugs, and additional tools i needed along the way
djb1187 is offline
Quick Reply: Another S/C Thread...
