clutch slipping?
Old 03-31-2008, 01:40 PM
steelybuns
steelybuns's Avatar
Default clutch slipping?
So lately when I've been cruising at a steady speed and I go to pass or just need some more power if I hit the gas hard the rpms will go up but the car wont move any faster, then it will go down and it will sort of "catch" and I'll get power to the wheels. Is that the clutch slipping? What else could it be if not that?
That being said, what clutch kit would you recommend (on the cheaper side)? I was reading a PDF file that summit has with their king cobra clutch and ford recommends a new flywheel, is that really needed?
steelybuns is offline
Old 03-31-2008, 01:44 PM
98SN95
98SN95's Avatar
Default RE: clutch slipping?
i have that clutch it works good, i have had it for a few months and at 70mph i can rev it to 3000rpm and dump the clutch and the car takes off like a rocket.
98SN95 is offline
Old 03-31-2008, 02:19 PM
Hash06
Hash06's Avatar
the only reason you will need a new flywheel is if it is cracked, if it is not cracked just get it resurfaced. the king cobra clutch kit is nice, i had it on my last gt
Hash06 is offline
Old 03-31-2008, 03:33 PM
Rusticgt
Rusticgt's Avatar
Try this, at the car at a stop put the car in first gear and put your foot on the break, let off the clutch, if the motor still sort of idles before it cuts out then I would change your clutch and flywheel.
Rusticgt is offline
Old 03-31-2008, 04:14 PM
MJH78
MJH78's Avatar
Yes your clutch is slipping. You can get some more life out of it though, just go easy on it.
MJH78 is offline
Old 03-31-2008, 04:22 PM
1999 GT
1999 GT's Avatar
yea def your clutch is slippin
1999 GT is offline
Old 03-31-2008, 04:36 PM
steelybuns
steelybuns's Avatar
that sucks... it was just replaced about 4 months ago. I dont know what kind of clutch is in it right now though. Will it be noticeable when it is just about to go out? This car is my daily driver and I'm in school so I dont have the cash to get it replaced right now. [:@]
Old 03-31-2008, 04:38 PM
steelybuns
steelybuns's Avatar
Also, I dont ride the clutch or anything but sometimes in traffic in order to inch up I have to engage the clutch halfway with it in first and give it some gas. Could that have worn it out so fast?
Old 04-01-2008, 11:46 AM
98SN95
98SN95's Avatar
IF THE CLUTCH is only 4 months old than you need some lessons on driving a 5-speed!!1
98SN95 is offline
Old 04-01-2008, 01:26 PM
cisurfer
cisurfer's Avatar
or you may be leaking some fluid onto the clutch...
cisurfer is offline
Thunderball
15
11-22-2015 11:49 PM
AmericanMuscle4.6GT
11-10-2015 02:06 PM
TCStangerv6
10-11-2015 05:57 PM
junior04
09-28-2015 10:53 AM
MacSerio
09-27-2015 01:05 PM
Quick Reply: clutch slipping?
