harmonic balancer
harmonic balancer
hello</P>
when and why would you want to upgrade the harmonic balancer / dampner? i've seen a few underdrive kits which come with them while others don't.</P>
thanks.</P>
harmonic balancer
Well, either if yours is bad (slipped) or you need to meet rules for racing which most require an aftermarket SFI approved dampner. Some kits come with them because they are required with the crank pulley change.
harmonic balancer
Not as far as the balancer itself is concerned, the aftermarket balancers are 1 piece and usually do a better job of keeping things in balance. They could be lighter too maybe, and that would reduce rotating weight.
harmonic balancer
I installed a set of Steeda underdrive pulleys, now I have a small oil leak coming from the balancer that came with the kit. Anyone know anything about this? Was a seal damaged at the time of installation??</P>
jessicarabbit
09-25-2015 12:41 PM
LivingInThePast
09-16-2015 12:20 PM
09-08-2015 11:50 AM
09-01-2015 08:16 PM
