4.6 engine swap, 04 into 96; help please
Old 04-20-2008, 01:48 PM
ferdigle
ferdigle's Avatar
Default 4.6 engine swap, 04 into 96; help please
I have a 96 4.6 and I have aquired a complete, new 2004 GT engine as a replacement.
The major difference is the ignition; Whereas I had 2 coilpacks, one for each bank, the new engine has 8 individual coils and each is wired into the wiring loom. Not sure of the best way to go.
Also I am in Calif. so trying to keep things sort of smog legal
ferdigle is offline
Old 04-20-2008, 02:12 PM
Sxynerd
Sxynerd's Avatar
Default RE: 4.6 engine swap, 04 into 96; help please
The ONLY thing you'll use in the swap is the Long block and accessories. You'll keep your Return style fuel, Wiring harness, 2 Coil packs and Wires... Think of it as the same motor... Taking bad one out putting the new one in. AND you wont fail emission visual inspection because the engines look almost identical. (they use a black and white picture) Only piece of good advise I can give is if your A/C works, then unbolt the pump from the block leaning everything connected and bolt it back up to the new engine and you wont have to refill you A/C.
Both are Romeo's so you wont need a new clutch like I did.
Sxynerd is offline
Old 04-20-2008, 02:14 PM
Sxynerd
Sxynerd's Avatar
One more thing, You may want to find a tunner that can give your ECU the fuel maps for the improved head and Cam design. I drove around with my like that for about 4 months with no issues.
Sxynerd is offline
Old 04-20-2008, 03:15 PM
ferdigle
ferdigle's Avatar
So I assume that you also mean I need to use my old intake and injectors?
Thanks for the A/C tip, I was going to try it that way.
ferdigle is offline
Old 04-20-2008, 03:33 PM
Sxynerd
Sxynerd's Avatar
No, new Intake "old Injectors" sorry if I wasn't clear. Don't know if you know it or not but your going to pick up 60 hp with that engine swap. I actually gained 81 with a tune. The intake is a better design and gives you a few more ponies.
Everything fuel, electrical, and spark related stay the same.
Sxynerd is offline
Granatelli Sales
01-20-2020 12:34 AM
MusicCity615
09-27-2015 12:53 AM
97SN95GT
09-13-2015 09:45 PM
mdj89
09-06-2015 11:08 PM
raleigh05GTO
09-04-2015 07:09 AM
Quick Reply: 4.6 engine swap, 04 into 96; help please
