Intake manifold and heads
Old 05-15-2008, 12:21 PM
brian1570
Blart
brian1570's Avatar
Default RE: Intake manifold and heads
yeah but do u wont FI on a completely stock motor???? or do u want h/c/i THEN fi? seems like this comes up way too much. but for the average joe blow who wants a mean steet beater, do H/C/I FIRST. then drive it a while, save up. and then swap to a low boost blower.
brian1570 is offline
Old 05-15-2008, 12:27 PM
bjh061487
bjh061487's Avatar
wouldn't he still be limited to the 400 rwhp or would he be able to run more horsepower? i only ask because his bottom end would still be stock and i was under the impression that the bottom end can only handle 400rwhp
bjh061487 is offline
Old 05-15-2008, 12:39 PM
BostonBruins 2003GT
BostonBruins 2003GT's Avatar
hey oxford -
how's the difference in power with the trickflow manifold? not necissarily hp/tq numbers...but can you tell if it pulls more up top?
also which setup did you get? the75mm single TB or the dual 'cobra' TB setup? Was considering getting a stronger intake once i get the heads/cams done, that can handle a larger giggle gas shot than the stock POS plastic peice....
BostonBruins 2003GT is offline
Old 05-15-2008, 12:49 PM
brian1570
Blart
brian1570's Avatar
ORIGINAL: bjh061487
yeah more or less. 400 rwhp is just an aproximate figure. but if he stayed around 6-9 psi there shouldnt be a problem. 400rwhp is nothing to sneeze at. thats a pretty damn stout 2v.
Old 05-15-2008, 01:10 PM
Fleet99GT
Fleet99GT's Avatar
I think im going to do the FI first with low boost. Then when the time is right i can get the low end built and then build the heads for low compression somewhere around 8.5:1. But a 2V running 6-8 lbs of boost is still respectable on the street. Also Im set on a Kenne Belle, doesnt that replace the stock intake manifold anyway?
Fleet99GT is offline
Old 05-15-2008, 01:12 PM
brian1570
Blart
brian1570's Avatar
oh well yeah if ur gonna do a KB it comes w/ an alum lower intake. it also comes w/ alot of other goodies i hope u have like 5k to spend on it tho.
Old 05-15-2008, 02:20 PM
Fleet99GT
Fleet99GT's Avatar
Ive just heard nothing but good things from kenne bell. I just dont want a centrifical sc.
Old 05-15-2008, 02:22 PM
1sloblckgt
1sloblckgt's Avatar
I'm about to go with CMS stage 2 heads and cams with a Hardballer intake manifold...Maybe up the spray a little bit.
1sloblckgt is offline
Old 05-15-2008, 02:25 PM
brian1570
Blart
brian1570's Avatar
yes KB is the way to go. very well put together systems. the shop i take my car to doesnt use anything other than KB. if u ask what supercharger u should do, their first answer is KB. only if u dont have the money to do aKB to will they recomend a centrifugal.
Old 05-15-2008, 02:26 PM
Fleet99GT
Fleet99GT's Avatar
How much will that set u back? How much spray, and do u already have a retard on your spark timing?
Quick Reply: Intake manifold and heads
