Old 11-04-2015, 12:17 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Powertrain Guides
Print Wikipost
How do you jump the fuel pump?
Old 07-21-2008, 08:27 PM
amoosenamedhank
amoosenamedhank's Avatar
Default How do you jump the fuel pump?
Like the title says, I'm not getting pressure to the fuel rail and I need to jump the pump to see if it's creating pressure.
amoosenamedhank is offline
Old 07-21-2008, 09:12 PM
vanquish
vanquish's Avatar
Default RE: How do you jump the fuel pump?
I would wire the pump directly with 12 volts and see if that will make the pump work. If it doesn't, it is a bad fuel pump. I am not sure but I believe you can hit the fuel tank area with a hammer while someone trys to start the car. If the car starts, you need a new fuel pump. This hammer solution is the same thing done to tell if a starter is bad.
vanquish is offline
Old 07-21-2008, 09:31 PM
Evenexchange
Evenexchange's Avatar
That is what the shop did when they diagnosed that my pump was bad.. and it was. Symptoms was the car would occasionally start.. but when it did the RPMs would drop and almost let the car die.
Evenexchange is offline
Old 07-21-2008, 09:40 PM
vanquish
vanquish's Avatar
With that 5.4 it looks like you are going to put in, I would buy a better pump(s) anyway.
vanquish is offline
Old 07-21-2008, 09:56 PM
blackstallion666
blackstallion666's Avatar
check and make sure the interia switch in the trunk wasn't tripped. The Brown and pink wire is the power feed to the pump. And the Dark green and yellow wire is the hot wire from the fuel pump relay(ccrm) to the inertia switch. Also check the fuel pump and eec fuse. the supply the power to the CCRM Which controls the fuelpump relay.
to jump it you can run a hot wire to the brown and pink wire found at the inertia switch.
blackstallion666 is offline
Old 07-21-2008, 10:06 PM
blackstallion666
heres a few more diagrams to help you.
you can also jump it at the (ccrm)Constant control relay module connector 192 in the diagram above. By jumping pin 11yellow wire and pin 5 dark green and yellow wire.
Old 07-22-2008, 04:16 AM
oxfordgt
oxfordgt's Avatar
You can go throug all that crazyness above or you can just trigger the inertia switch then run a 12v line from battery to the pump supply wire (after the inertia switch) andput a switch inline.If you are just doing this to test the pump.
oxfordgt is offline
Old 07-22-2008, 08:31 AM
contentsunderpressur
contentsunderpressur's Avatar
I've always just unpluged the fuel pump relay and jumped it right there.
contentsunderpressur is offline
Old 07-22-2008, 09:14 AM
califas_1987
califas_1987's Avatar
WOW! Kick *** diagrams!
In re: to the pump, I always would just listen to see if it kicks in when I turn the ignition. If it doesn't, check the inertia switch, check the fuses, and the wiring. If all checks out; time to drop in a new one.
Do you let your car go below or around 1/8th of a tank on a regular basis?
You might want to replace the sending unit while you are at it; might as well do it all right while it is down. I had a bad sending unit once that markedmore fuel than in actuality. As a result I would always run the car with little fuel in the tank. I went through 3 pumps in 3 years.
califas_1987 is offline
Old 05-11-2017, 02:16 PM
jc51chvy
jc51chvy's Avatar
If its hot at inertia switch and jump it shouldn't the pump kick on?
jc51chvy is offline
Quick Reply: How do you jump the fuel pump?
