Help, #7 Ignition Coil Shorted/TB Problem
I'd get some Seafoam for the TB.
For the #7 coil... doesn't your car have Coil On Plugs? If so, you can buy a new, single COP for like $30-$50 (don't recall exactly) from the local parts desk. If you still have coil packs, I want to say a pair is about $150, and take the opportunity to upgrade to like an MSD Blaster pack.
And yes, a dead cylinder can cause all the problems you mentioned.
If I were you I would do everything yourself. I'm sure someone on the forum has an extra COP they would sell you for dirt cheap. While your cleaning the TB take the time to clean out your IAC and MAF too. Disconnect the battery for 20 minutes then start up your car and it should run like new!
HI I NEED HELP WITH THIS PROBLEM IS DRIVING ME CRAZY, I OWN A 2002 FORD MUSTANG 5 SPEED,V6 3.8 ENGINE I DO NOT HAVE SPARK IN LAST TWO CONECTIONS OF A SIX PACK COIL I ALREADY REPLACE 3 BRAND NEW COILS I ONLY GET SPARK IN THE 2 ROW OF THE THE COIL TOP AND BOTTON FIRST 4 ,AND LAS TWO NO SPARK AT ALL THANKS FOR YOUR HELP
Well it sounds like you have a grounding problem. The PCM controls ground for each set of wires (3 pairs of 2) I believe 1,5 have the same ground, 3,4 same ground, 2,6 same ground. So tell me which specific 2 cylinders arent getting spark. You either have a wiring issue or a PCM problem.
2nd. Next time you post try using basic 8th grade grammar, punctuation, and syntax and you'll get more help. (We don't ask for much)
3rd. Which happens to be my Favorite because of the picture I get to post:
........------v
We love helping out but give everyone the respect they deserve by speaking (typing) at a mature level with thoughtful and specific detail.
