Front defroster doesn't remove moisture from windshield??
Old 12-17-2008, 05:02 PM
marker227
marker227's Avatar
No, the car is completely dry when I get in the car.
marker227 is offline
Old 12-17-2008, 05:23 PM
vanquish
vanquish's Avatar
Did you try cleaning the window from the inside with invisible glass or windex? Sometimes when my window fogs it does so in a pattern that looks like streaks if I do a bad job cleaning the window.
vanquish is offline
Old 12-17-2008, 05:26 PM
marker227
marker227's Avatar
It's not streaks from fingerprints. It's actual moisture. You can see it go away... And I wipe it away every 10 minutes or so when its really cold out.
Old 12-17-2008, 07:43 PM
BraMas
BraMas's Avatar
Rain X makes an anti fog product that you wipe on your windows. Get some of that and see if it helps
BraMas is offline
Old 12-17-2008, 08:44 PM
marker227
marker227's Avatar
edit>>>>>
Old 12-17-2008, 08:48 PM
marker227
marker227's Avatar
It's 36 F out with 88% humidity it says for NJ.
I took these pictures as soon as I got in my car tonight.
The 2nd to last picture is AFTER I wiped it down with a towel.
2nd picture you can see I drew a smiley face in it.
4th picture down is what it looks like when I am driving without wiping it down with a towel. The right side is more cloudy since I didn't touch that area... You can see how it's hard to see through.
Old 12-17-2008, 10:12 PM
massred98gt
massred98gt's Avatar
thats pretty strange dude. my a/c is broken and i don't even have problems like that. i mean it doesn't defrost as quickly as it should because i'm blowing warm moist air into the car, but when it gets bad sometimes i just crack the window alittle and it helps. it only happens when its raining for me atleast. are u positive ur a/c is workin?????
massred98gt is offline
Old 12-17-2008, 10:14 PM
Hicompression
Hicompression's Avatar
Question
How many minutes after making out with some hot chick did you say you got back in and drove the car??
Hicompression is offline
Old 12-17-2008, 10:18 PM
marker227
marker227's Avatar
I'm only saying my A/C works because it puts out cold air...
I'll get my car looked at this week by a mechanic? Maybe my freon is low? I got it recharged last year since it came without it... (previous owner drained freon to race it I think)
Old 12-17-2008, 10:58 PM
jivepepper
jivepepper's Avatar
Do you ever smell antifreeze? If your heater core leaks a little it will do that. Even though the ac helps it's not neseccary. Lot of people delete their AC's
jivepepper is offline
Quick Reply: Front defroster doesn't remove moisture from windshield??
