snapped off lug..
Old 01-31-2009, 12:18 PM
1999 GT
1999 GT's Avatar
Default snapped off lug..
i was putting my saleens back on today and i was taking the bullitt off the rear drivers side and i snapped off one of the lugs. half of it is stuck inside the lug nut and the stub that is left is too small to get the lug nut on. what do i need to fix this, and is it ok to drive?
1999 GT is offline
Old 01-31-2009, 03:35 PM
vanquish
vanquish's Avatar
Were these chrome lug nuts that are really a chrome cap over a regular lug nut? I don't really understand your explanation of how the lug nut broke. I would still drive the car with 4 lug nuts on.
vanquish is offline
Old 01-31-2009, 03:40 PM
HateWhatOwnsYou
HateWhatOwnsYou's Avatar
the stud broke.....
HateWhatOwnsYou is offline
Old 01-31-2009, 03:53 PM
1999 GT
1999 GT's Avatar
^ yea
1999 GT is offline
Old 01-31-2009, 03:54 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
Its a fairly easy fix man. Get the wheel off, take the rotor off, and then using a BFH smack the stud out.(you should be able to spin the axle around to a spot where the stud will slide out..i havent had to replace one on a mustang yet so you might have to pull the axle out if not) Get a new stud, a stack of washers, and a new lugnut and using an impact gun, slowly press the new one in. Viola, done
WhiteFoxGT is offline
Old 01-31-2009, 04:09 PM
tncruiser
tncruiser's Avatar
what he said but i prefer a red
fn hammer over the black
tncruiser is offline
Old 01-31-2009, 04:44 PM
StuzGT
StuzGT's Avatar
I was spinning wheels on 4 lugs when I bought my 2000 in 2008...
...but you should repair it asap...
The lug on mine was stripped and was also the rear drivers side...
you will be able to use a BFH to knock the lug out but you will have to do some finnagling to get it past the hub...
I thought I was going to have to remove the axle to get it out but it does come out...
...and the new lug will go in with some coaxing...
Then as WhiteFoxGT indicated, with the new lug in place, stack washers under the lugnut and use an impact gun to pull the new stud into place...
I did and now spinning wheels on 5 lugs
StuzGT is offline
Old 01-31-2009, 04:56 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
You ready for that spring install yet bud?
I got some C-springs here I'd be happy to donate. Just fly me on down to the nice weather and I'll be happier than a pig in ****
Old 01-31-2009, 05:05 PM
StuzGT
StuzGT's Avatar
all my tools are laid out for the job...
This is what your looking for
...and dont loose your head in the process
(the Corvette shirt is optional )
StuzGT is offline
Old 01-31-2009, 05:10 PM
StuzGT
StuzGT's Avatar
...nice weather! ...its freezing out...gotta be 50 something degrees out
Are you in sales?
StuzGT is offline
Quick Reply: snapped off lug..
