electric waterpump
haha I don't want to argue either. I'm just thinking of possible stuff to do to squeeze out a few more hp. At this point though, I'm saving up for a Kenne Bell and that 400 for the electric water pump isn't something I'd say I really need. Maybe for a drag car.
I'm just done with all the bolt ons pretty much so it's time for the big boy stuff
i was thinking of doin this mod pretty simple and im not sure bout the UD causing u to lose voltage a lot of poeple have this done and have systen and they say its fine plus couldnt u jus change hte size of ur UD pulley jus like on a supercharger
A UDP alternator pulley charges the system 25% less...Ask anyone.
well i have UDPs..and ill be ordering this pump shortly so when i get it in the car ill let everyone know if i have any charging issues..if worst come to worst cant you just find a heavyduty/ high output alternator?
It only charges 25% less at idle, and most high output alternators actually put out less than stockers at idle, they just make up for it once the RPMs go over 1200 or so. Unless you have to sit in heavy traffic without going over 1200 rpms for long periods of time, that 25% won't hurt you at all. You may watch your voltage drop a little if you get stuck in traffic, but hit the gas a little, and watch it pop right back up to normal.
